Hello,
I have buy a 2nd hand 11th i7-1165g7 motherboard and i thinks i have a problem with the FAN.
I have try whis 3 OS Windows, Ubuntu and Arch with and whitout battery.
BIOS 3.19.
The problem is the FAN are alway hight or to loud, but he never go higher or better.
I doesn’t have sensor for have RPM of the fan with lm-sensors.
the CPU is at 25°C and the noise is horrible.
a have try to use fw-ectool and the github plugin for the fan and the command not modify the RPM of the fan.
Do you think is a motherbord or a fan problem?
What can i do resolve this issue?
Thanks for your help.
