I have windows and linux installed on my framework 16. When i restart the machine it automatically starts to boot windows. If i mash the f12 (Framework) key and go into bios i can choose fedora (it shows windows at the top then two boot options for fedora) but when ever it boot cycles (ie when doing an OS update) it goes back to booting windows.
Also it doesn’t let me change the boot order in bios
How do i fix that ?
and secondly the boot menu in fedora (grub) is very small text how do i make it bigger.
You can change boot order in bios, even if it is a bit not intuitive.
You select as a bios order first or last (not auto) and then go in the list of bootable systems.
You then press F5 or F6 to rise or lower each system.
this fixes the menu resolution. To fix the boot menu and have it default to grub i went into the framework BIOS and chose boot menu, this is usually showing read only but you have to remove the lock on the previous screen to get in and change the boot order
“new boot device priority” set to manual
