FW 13 amd DIY
windows 11
been having an issue where after a while ill get a notification from windows saying theres an error with a usb device after which whenever i leave my mouse still and then try to move it then it wont move but if i open up the bluetooth menu itll start working i dont even need to connect its already connected even in the quick menu it says its connected to the mouse its only when i open it up to see all the connected devices that it magically works again
ive tried uninstalling the driver for that device which hasnt worked but whenever i do uninstall it then the issue goes away but of course windows just reinstalls it automatically and i assume that the device is important so i dont really want to look for a way to permanently uninstall it
(when i say uninstall device i mean this
ive looked up the error code best i get is to uninstall device which i already did
any ideas?
edit: no longer magically works if i uninstall the device
if i disable it i still have the issue to
after a quick restart and a reseating of the wifi card booted up device manager and it appeared the error shows from the start
[fixed]: if i dont update this i reinstalled the drivers from frameworks website that they give you for installing your wifi card drivers and ive not had the issue come up yet if this doesnt get updated then that means it fixed the issue
