My laptop won’t wake from sleep. The general steps to reproduce are:
Unplug power adapter
Close the laptop lid
…a few hours later…
Open the laptop lid
At this point, the laptop won’t respond to opening the lid or pressing the power button (which is pulsating normally). I’ve noticed that if I leave the laptop like this, it tends to get hot. The only way out of this situation is to hard reset the machine (by pressing and holding the power button until the machine turns off).
Please note that the steps outlined above don’t always trigger the issue, and there might be other pathways to triggering the issue. Unfortunately, this issue occurs randomly, usually at the most inconveninet of times .
% fwupdmgr get-updates 2 ↵
Devices with no available firmware updates:
• Fingerprint Sensor
• WD BLACK SN850X 1000GB
Devices with the latest available firmware version:
• System Firmware
• UEFI dbx
No updates available
As of right now, this is the only issue I’ve encountered; otherwise, everything is working perfectly.
In my case, the power button pulsates but the laptop otherwise doesn’t respond. I should probably plug the laptop into a dock the next time this happens to see if the laptop is functional but the screen & keyboard are non-responsive. However, when I restart the laptop, it works normally.
I should clarify that the steps I outlined don’t always reproduce the issue, and there might be other pathways to running into the described issue; it’s random, essentially, which is what makes it really difficult to diagnose.
How did you update the hard drive firmware? Also, how do I find out what firmware version the drive is running currently?? As an FYI, I don’t have access to a Windows machine. Per LFVS, there are no updates available:
• System Firmware
• UEFI dbx
Here’s more details about my SSD (please note the model in particular):
The article you linked seems to be applicable to Intel models only. Should I still follow it but skip any parts directly related to the CMOS battery?
I didn’t remember to check dmesg, only journalctl (nothing interesting there). Next time this happens, I’ll dump dmesg output to a file to review on boot.
I’ll open up the laptop to ensure the keyboard is fully plugged in.
The interesting bits are probably just before sleep, but you can check kernel logs (dmesg) of the previous boot with: journalctl -k -b -1.
Edit: I would also unplug the battery connector for ~2 minutes. I have solved issues (on other systems) doing that in the past. Won’t do any harm (if you’re very careful with the connector )
Ok, I have gotten the error again (multiple times) . Here are some messages from the prev log - sudo journalctl -k -b -1:
sda: detected capacity change from 15695871 to 0
usb 7-1: USB disconnect, device number 2
ucsi_acpi USBC000:00: ucsi_handle_connector_change: ACK failed (-110)
i2c_designware AMDI0010:00: i2c_dw_handle_tx_abort: lost arbitration
usb 1-4: reset full-speed USB device number 2 using xhci_hcd
Lockdown: systemd-logind: hibernation is restricted; see man kernel_lockdown.7
wlp1s0: deauthenticating from 80:da:13:1c:6f:f4 by local choice (Reason: 3=DEAUTH_LEAVING)
PM: suspend entry (s2idle)
Some messages from the current log - sudo journalctl -k -b:
Linux version 6.7.10-200.fc39.x86_64 (mockbuild@ae08434938294146bc90abcf84c6afc4) (gcc (GCC) 13.2.1 20231205 (Red Hat 13.2.1-6), GNU ld versi
Command line: BOOT_IMAGE=(hd0,gpt2)/vmlinuz-6.7.10-200.fc39.x86_64 root=UUID=8daddb32-144a-4731-8615-babf8e92b328 ro rootflags=subvol=root rd
BIOS-provided physical RAM map:
BIOS-e820: [mem 0x0000000000000000-0x000000000009efff] usable
BIOS-e820: [mem 0x000000000009f000-0x00000000000bffff] reserved
--- xxx ---
Filtered faults from the current log - sudo journalctl -k -b -p 0..4:
ACPI BIOS Warning (bug): Optional FADT field Pm2ControlBlock has valid Length but zero Address: 0x0000000000000000/0x1 (20230628/tbfadt-615)
Speculative Return Stack Overflow: IBPB-extending microcode not applied!
Speculative Return Stack Overflow: WARNING: See https://kernel.org/doc/html/latest/admin-guide/hw-vuln/srso.html for mitigation options.
pci 0000:00:00.2: can't derive routing for PCI INT A
pci 0000:00:00.2: PCI INT A: not connected
i8042: PNP: PS/2 appears to have AUX port disabled, if this is incorrect please boot with i8042.nopnp
i8042: Warning: Keylock active
device-mapper: core: CONFIG_IMA_DISABLE_HTABLE is disabled. Duplicate IMA measurements will not be recorded in the IMA log.
integrity: Problem loading X.509 certificate -126
journald[1199]: File /var/log/journal/f52cfc18b87d4b3aa53b48035d04b121/system.journal corrupted or uncleanly shut down, renaming and replacin
cros_ec_lpcs cros_ec_lpcs.0: EC ID not detected
journald[1199]: File /var/log/journal/f52cfc18b87d4b3aa53b48035d04b121/user-1000.journal corrupted or uncleanly shut down, renaming and repla
Bluetooth: hci0: HCI Enhanced Setup Synchronous Connection command is advertised, but not supported.
i2c_hid_acpi i2c-FRMW0005:00: i2c_hid_get_input: incomplete report (7/65535)
These shutdowns have been happening with or without power adapter attached, with lid closed or open, and on Fedora and Ubuntu both (officially supported versions with post-install workarounds applied).
The computer gets really hot every time this happens and once I reset it, the fan goes on full blast for a while too (this has been consistent).
OK, it seems the issue is resolved after updating to the latest kernel (released 1-2 days ago). I’m currently running kernel version 6.7.11-200.fc39.x86_64 and the computer is able to recover from sleep normally.
I’ll keep an eye on the system for the next few days and post back here at the end of the observation period.
I’m happy to report that the laptop has consistently been able to wake up since upgrading the kernel from version 6.7.10-200.fc39.x86_64 to 6.7.11-200.fc39.x86_64.
In retrospect, when I was at version 6.7.10-200.fc39.x86_64, had I tried booting the system with the previous version of the kernel, I could have saved myself a lot of pain. @Loell_Framework, perhaps the troubleshooting guide should explicitly mention booting with the previous version of the kernel to see if that helps with an issue (particularly if it’s) introduced by an update.
