Since i started using my new ryzen 13 inch the screen will occasionally glitch, see photo. The pixels form in large blocks and the responsivity of the system collapses. Please help!!
That looks less good !
Does it occur if you use a live CD/USB of supported O/S ?
If yes, have you checked all the cables are correctly seated ?
I find it odd that its most of the screen, not all of it
hi @Quinten_McElhiney , welcome to the community. ![]()
As @tom_chiverton suggest,
do check out if this is happening on Ubuntu 22.04+ or Fedora 39+ Live, May need to run for several ours to be sure if it’s happening or not.
