Screen Bottom Half Glitch/Ghosting
Just recieved my new laptop yesterday. Today I started getting a weird display flicker/Ghosting. Has any one seen anything like this or know what to look at to fix it? It happens in the bios and in OS.
https://youtu.be/0ipNgrtjFek
https://youtu.be/4m7tlphUNdg
Hi Matt. I would definitely suggest you contact Framework Support for them to be able to assess the issue.
Here’s the link
Hello, I just received my laptop and I seem to be having the exact same issue. Are you by any chance running fedora 35? Has there been any updates or fixes to your situation? I am trying to figure out if I need a screen replacement or if this is a software/firmware issue.
I was using Fedora 35, however for me it showed symptoms at bios as well. The lcd was replaced to resolve.
Alright, thank you very much for the answer. Do you by chance know if customers who are still under warranty are eligible for free or discounted replacement parts?
I would reach out to them.
