Using the Framework 13 intel 11th gen for about a year and a half.
Today I saw the power/fingerprint sensor light flickering for the first time. Happened when plugged in, on battery, or while sleeping.
It seemed to go away shortly after sleeping and waking.
Not sure what caused this.
Looks like a hardware issue to me. Perhaps a loose connection. I’d try re-seating the cable. If that doesn’t help, I’d contact support.
Hi @skysurveil,
You will want to reseat the input cable under the keyboard. Power on and check again. If it’s still an issue, please open a support ticket linking to this thread.
