Hi guys,
How can I troubleshoot this one USB device drawing the 8 or so watts in powertop? I have no USB devices connected, but I have two USB C, One USB A, and one HDMI slots in the framework currently. Appreciate any help!
Hi guys,
Hi and welcome to the forum.
There are issue with the USB A and HDMI
Have you tried with neither or only one to see what is happening, also search the forum for lots more info.
The hdmi and usb-a are almost definitely the culprits but you likely also have turboboost enabled on battery. For battery life TLP and all usb-c expansion cards are the way to go.
@nadb Turning off turboboost has made a significant difference, and yeah I have tlp installed too. Thanks for the help as well @amoun
This sounds like the HDMI expansion card is at play here. They can use a bit more power than other card. Have you tried testing one card at a time, to see if this may indeed be the HDMI card drawing the wattage?
