On my Intel Ultra 165H the sensorscommand gives the output below. I am wondering if there is a reference on what which sensor refers to. For example there are multiple sensors that seem to refer to the CPU temperature (all the coretemp-isa-0000.* sensors or the cros_ec-isa-0000.cpu_f75303@4dsensor) but all are reading different temperatures. Then there are various fans listed, etc.
It would be nice to know what is what and what to keep an eye on.
ucsi_source_psy_USBC000:004-isa-0000
Adapter: ISA adapter
in0: 20.00 V (min = +5.00 V, max = +38.80 V)
curr1: 2.25 A (max = +3.16 A)
ucsi_source_psy_USBC000:001-isa-0000
in0: 0.00 V (min = +0.00 V, max = +0.00 V)
curr1: 0.00 A (max = +0.00 A)
iwlwifi_1-virtual-0
Adapter: Virtual device
temp1: +55.0°C
spd5118-i2c-14-50
Adapter: SMBus I801 adapter at efa0
temp1: +50.5°C (low = +0.0°C, high = +55.0°C)
(crit low = +0.0°C, crit = +85.0°C)
coretemp-isa-0000
Package id 0: +56.0°C (high = +110.0°C, crit = +110.0°C)
Core 0: +52.0°C (high = +110.0°C, crit = +110.0°C)
Core 1: +51.0°C (high = +110.0°C, crit = +110.0°C)
Core 2: +52.0°C (high = +110.0°C, crit = +110.0°C)
Core 3: +52.0°C (high = +110.0°C, crit = +110.0°C)
Core 4: +51.0°C (high = +110.0°C, crit = +110.0°C)
Core 5: +52.0°C (high = +110.0°C, crit = +110.0°C)
Core 6: +52.0°C (high = +110.0°C, crit = +110.0°C)
Core 7: +52.0°C (high = +110.0°C, crit = +110.0°C)
Core 8: +57.0°C (high = +110.0°C, crit = +110.0°C)
Core 12: +51.0°C (high = +110.0°C, crit = +110.0°C)
Core 16: +54.0°C (high = +110.0°C, crit = +110.0°C)
Core 20: +51.0°C (high = +110.0°C, crit = +110.0°C)
Core 24: +51.0°C (high = +110.0°C, crit = +110.0°C)
Core 28: +50.0°C (high = +110.0°C, crit = +110.0°C)
Core 32: +55.0°C (high = +110.0°C, crit = +110.0°C)
Core 33: +55.0°C (high = +110.0°C, crit = +110.0°C)
BAT1-acpi-0
Adapter: ACPI interface
in0: 16.21 V
curr1: 1.96 A
acpi_fan-acpi-0
fan1: 0 RPM
power1: 0.00 W
cros_ec-isa-0000
fan1: 0 RPM
local_f75397@4c: +44.9°C
cpu_f75303@4d: +47.9°C
battery_temp@b: +39.9°C
ddr_f75303@4d: +42.9°C
peci-temp: +54.9°C
ucsi_source_psy_USBC000:003-isa-0000
in0: 5.00 V (min = +5.00 V, max = +5.00 V)
curr1: 0.00 A (max = +3.00 A)
spd5118-i2c-14-52
temp1: +49.2°C (low = +0.0°C, high = +55.0°C)
ucsi_source_psy_USBC000:002-isa-0000
curr1: 680.00 mA (max = +0.00 A)
nvme-pci-a900
Adapter: PCI adapter
Composite: +45.9°C (low = -5.2°C, high = +89.8°C)
(crit = +93.8°C)
acpitz-acpi-0
temp1: +54.8°C
temp2: +47.9°C
temp3: +42.9°C
temp4: +44.9°C
temp5: +40.0°C
acpi_fan-acpi-0
fan1: N/A
power1: N/A
