Which Linux distro are you using? Ubuntu
Which release version? 24.04
Which kernel are you using? Linux 6.8.0-52-generic
Which BIOS version are you using? Vendor: INSYDE Corp. Version: 03.05
Which Framework Laptop 16 model are you using? AMD Ryzen™ 7040 Series
Hi all, I’m working to get Steam set up for my Framework 16 laptop, using Step 11 of the Ubuntu 24.04 Guide as a reference.
However, I have a couple questions:
- I do not have the graphics module expansion bay, do I still want to configure for discrete graphics?
- Assuming “yes”, then the next question is:
I have both a primary and secondary NVMe installed in the laptop, but only the primary is used with Ubuntu (where I’d like to set up Steam). The other is used for dual-booting Windows. Should I follow the one or two NVMe instructions?
Thanks - any help is appreciated!
