- Framework Laptop DIY Edition (12th Gen)
- Linux Mint 21.1 (Vera)
I’ve a Logitech Pebble Bluetooth mouse connected to the internal Intel AX210 Bluetooth receiver. This basically works, but the mouse always “hangs” for 0.5s after 2s of inactivity.
After searching the internet and this forum, I found out, that this has something to do with USB autosuspend. I already have following udev rule created which disables autosuspend for the Intel AX210 Bluetooth receiver(/etc/udev/rules.d/99-usb_power_save.rules):
# blacklist for usb autosuspend
# Intel AX210 Bluetooth(embedded bluetooth receiver), solves mouse lag
SUBSYSTEM=="usb", ATTR{idVendor}=="8087", ATTR{idProduct}=="0032", TEST=="power/control", ATTR{power/control}="on"
This rule works and solves the problem when run manually using sudo udevadm trigger.
My problem now is, that this is rule is not working on boot.
Any idea why this rule works manually but not on boot?
