Apologies to deviate from the topic a bit but I have same SSD build (Samsung 990Pro 2TB) with Framework16 which just arrived.
I am a bit bummed out that I am not able to boot using a Live Flash drive.
I keep getting the following error message:
Default Boot Device Missing or Boot failed.
Insert Recovery media and hit any key…
Did you run into anything when setting up your laptop @schentuu ? I am attempting (and miserably failing atm) to install NixOS Linux distro on this.
Any help/guidance would be really appreciated.
Cheers!
EDIT:
Turns out it was just me being dumb. Had to disable secure boot and everything works fine now.
