I disabled the cores only for testing, I don’t use it like that, however, it tames the best, ie it always stays at that 11W and it doesn’t heat up to 100 degrees under load.
@Kamil_Iskra
Expansion cards draw only less than 1W each, so removing them reduces the power draw to ~9W.
I did the tutorial from the link in the first post, so yes, I do have tlp. Tlp-stats below.
@Shiroudan
I didn’t show power for me.
I am at the 6.2.0-26-generic, but I had the same issue on 5.19 and 5.15.
--- TLP 1.5.0 --------------------------------------------
+++ Configured Settings:
defaults.conf L0004: TLP_ENABLE="1"
defaults.conf L0005: TLP_WARN_LEVEL="3"
defaults.conf L0006: TLP_PERSISTENT_DEFAULT="0"
defaults.conf L0007: DISK_IDLE_SECS_ON_AC="0"
defaults.conf L0008: DISK_IDLE_SECS_ON_BAT="2"
defaults.conf L0009: MAX_LOST_WORK_SECS_ON_AC="15"
defaults.conf L0010: MAX_LOST_WORK_SECS_ON_BAT="60"
/etc/tlp.conf L0124: CPU_ENERGY_PERF_POLICY_ON_AC="performance"
/etc/tlp.conf L0125: CPU_ENERGY_PERF_POLICY_ON_BAT="power"
defaults.conf L0013: SCHED_POWERSAVE_ON_AC="0"
defaults.conf L0014: SCHED_POWERSAVE_ON_BAT="1"
defaults.conf L0015: NMI_WATCHDOG="0"
defaults.conf L0016: DISK_DEVICES="nvme0n1 sda"
defaults.conf L0017: DISK_APM_LEVEL_ON_AC="254 254"
defaults.conf L0018: DISK_APM_LEVEL_ON_BAT="128 128"
defaults.conf L0019: DISK_APM_CLASS_DENYLIST="usb ieee1394"
defaults.conf L0020: DISK_IOSCHED="keep keep"
defaults.conf L0021: SATA_LINKPWR_ON_AC="med_power_with_dipm max_performance"
defaults.conf L0022: SATA_LINKPWR_ON_BAT="med_power_with_dipm min_power"
defaults.conf L0023: AHCI_RUNTIME_PM_ON_AC="on"
defaults.conf L0024: AHCI_RUNTIME_PM_ON_BAT="auto"
defaults.conf L0025: AHCI_RUNTIME_PM_TIMEOUT="15"
defaults.conf L0026: PCIE_ASPM_ON_AC="default"
/etc/tlp.conf L0364: PCIE_ASPM_ON_BAT="powersupersave"
/etc/tlp.conf L0314: RADEON_DPM_PERF_LEVEL_ON_AC=""
/etc/tlp.conf L0315: RADEON_DPM_PERF_LEVEL_ON_BAT=""
/etc/tlp.conf L0329: RADEON_POWER_PROFILE_ON_AC=""
/etc/tlp.conf L0330: RADEON_POWER_PROFILE_ON_BAT=""
defaults.conf L0032: WIFI_PWR_ON_AC="off"
/etc/tlp.conf L0336: WIFI_PWR_ON_BAT="off"
defaults.conf L0034: WOL_DISABLE="Y"
defaults.conf L0035: SOUND_POWER_SAVE_ON_AC="1"
defaults.conf L0036: SOUND_POWER_SAVE_ON_BAT="1"
defaults.conf L0037: SOUND_POWER_SAVE_CONTROLLER="Y"
defaults.conf L0038: BAY_POWEROFF_ON_AC="0"
defaults.conf L0039: BAY_POWEROFF_ON_BAT="0"
defaults.conf L0040: BAY_DEVICE="sr0"
defaults.conf L0041: RUNTIME_PM_ON_AC="on"
defaults.conf L0042: RUNTIME_PM_ON_BAT="auto"
/etc/tlp.conf L0387: RUNTIME_PM_DRIVER_DENYLIST=""
defaults.conf L0044: USB_AUTOSUSPEND="1"
defaults.conf L0045: USB_EXCLUDE_AUDIO="1"
defaults.conf L0046: USB_EXCLUDE_BTUSB="0"
defaults.conf L0047: USB_EXCLUDE_PHONE="0"
defaults.conf L0048: USB_EXCLUDE_PRINTER="1"
defaults.conf L0049: USB_EXCLUDE_WWAN="0"
defaults.conf L0050: USB_AUTOSUSPEND_DISABLE_ON_SHUTDOWN="0"
defaults.conf L0051: RESTORE_DEVICE_STATE_ON_STARTUP="0"
defaults.conf L0052: RESTORE_THRESHOLDS_ON_BAT="0"
defaults.conf L0053: NATACPI_ENABLE="1"
defaults.conf L0054: TPACPI_ENABLE="1"
defaults.conf L0055: TPSMAPI_ENABLE="1"
/etc/tlp.conf L0087: CPU_SCALING_GOVERNOR_ON_AC="performance"
/etc/tlp.conf L0088: CPU_SCALING_GOVERNOR_ON_BAT="powersave"
/etc/tlp.conf L0134: CPU_MIN_PERF_ON_AC="0"
/etc/tlp.conf L0135: CPU_MAX_PERF_ON_AC="100"
/etc/tlp.conf L0136: CPU_MIN_PERF_ON_BAT="0"
/etc/tlp.conf L0137: CPU_MAX_PERF_ON_BAT="30"
/etc/tlp.conf L0149: CPU_BOOST_ON_AC="1"
/etc/tlp.conf L0150: CPU_BOOST_ON_BAT="0"
/etc/tlp.conf L0158: CPU_HWP_DYN_BOOST_ON_AC="1"
/etc/tlp.conf L0159: CPU_HWP_DYN_BOOST_ON_BAT="0"
/etc/tlp.conf L0189: PLATFORM_PROFILE_ON_AC="performance"
/etc/tlp.conf L0190: PLATFORM_PROFILE_ON_BAT="low-power"
/etc/tlp.conf L0302: INTEL_GPU_MIN_FREQ_ON_AC="100"
/etc/tlp.conf L0303: INTEL_GPU_MIN_FREQ_ON_BAT="100"
/etc/tlp.conf L0304: INTEL_GPU_MAX_FREQ_ON_AC="1500"
/etc/tlp.conf L0305: INTEL_GPU_MAX_FREQ_ON_BAT="800"
/etc/tlp.conf L0306: INTEL_GPU_BOOST_FREQ_ON_AC="1500"
/etc/tlp.conf L0307: INTEL_GPU_BOOST_FREQ_ON_BAT="1000"
+++ System Info
System = Framework A4 Laptop (13th Gen Intel Core)
BIOS = 03.03
OS Release = KDE neon 5.27
Kernel = 6.2.0-26-generic #26~22.04.1-Ubuntu SMP PREEMPT_DYNAMIC Thu Jul 13 16:27:29 UTC 2 x86_64
/proc/cmdline = BOOT_IMAGE=/boot/vmlinuz-6.2.0-26-generic root=UUID=0719daf5-3d44-47f2-bb69-13471a992566 ro text mem_sleep_default=deep nvme.noacpi=1 module_blacklist=hid_sensor_hub
Init system = systemd v249 (249.11-0ubuntu3.9)
Boot mode = UEFI
+++ TLP Status
State = enabled
RDW state = enabled
Last run = 21:36:43, 144 sec(s) ago
Mode = battery
Power source = battery
+++ Processor
CPU model = 13th Gen Intel(R) Core(TM) i5-1340P
/sys/devices/system/cpu/cpu0/cpufreq/scaling_driver = intel_pstate
/sys/devices/system/cpu/cpu0/cpufreq/scaling_governor = powersave
/sys/devices/system/cpu/cpu0/cpufreq/scaling_available_governors = performance powersave
/sys/devices/system/cpu/cpu0/cpufreq/scaling_min_freq = 400000 [kHz]
/sys/devices/system/cpu/cpu0/cpufreq/scaling_max_freq = 1900000 [kHz]
/sys/devices/system/cpu/cpu0/cpufreq/energy_performance_preference = power [HWP.EPP]
/sys/devices/system/cpu/cpu0/cpufreq/energy_performance_available_preferences = default performance balance_performance balance_power power
/sys/devices/system/cpu/cpu1..cpu15: omitted for clarity, use -v to show all
/sys/devices/system/cpu/intel_pstate/status = active
/sys/devices/system/cpu/intel_pstate/min_perf_pct = 10 [%]
/sys/devices/system/cpu/intel_pstate/max_perf_pct = 30 [%]
/sys/devices/system/cpu/intel_pstate/no_turbo = 1
/sys/devices/system/cpu/intel_pstate/hwp_dynamic_boost = 0
/sys/devices/system/cpu/intel_pstate/turbo_pct = (not available)
/sys/devices/system/cpu/intel_pstate/num_pstates = (not available)
/sys/module/workqueue/parameters/power_efficient = Y
/proc/sys/kernel/nmi_watchdog = 0
+++ Platform Profile
/sys/firmware/acpi/platform_profile = (not available)
/sys/firmware/acpi/platform_profile_choices = (not available)
+++ Temperatures
CPU temp = 47 [°C]
Fan speed = (not available)
+++ File System
/proc/sys/vm/laptop_mode = 2
/proc/sys/vm/dirty_writeback_centisecs = 6000
/proc/sys/vm/dirty_expire_centisecs = 6000
/proc/sys/vm/dirty_ratio = 20
/proc/sys/vm/dirty_background_ratio = 10
+++ Disks
Devices = nvme0n1 sda
/dev/nvme0n1:
Type = NVMe
Disk ID = nvme-WDS500G1X0E-00AFY0_21152R801585
Model = WDS500G1X0E-00AFY0
Firmware = 614300WD
Temp = 36 °C
Scheduler = [none] mq-deadline (multi queue)
Runtime PM:
/sys/block/nvme0n1/device/power/control = auto, autosuspend_delay_ms = (not available)
SMART info:
Critical Warning: 0x00
Temperature: 36 Celsius
Available Spare: 100%
Available Spare Threshold: 10%
Percentage Used: 0%
Data Units Written: 11 979 725 [6.13 TB]
Power Cycles: 2 587
Power On Hours: 5 055
Unsafe Shutdowns: 105
Media and Data Integrity Errors: 0
/dev/sda:
Type = USB
Disk ID = usb-SMI_USB_DISK_AA00000000015055-0:0
Model = SMI USB DISK
Firmware = unknown
APM Level = none/disabled
Status = standby
Scheduler = none [mq-deadline] (multi queue)
Runtime PM:
/sys/block/sda/device/power/control = auto, autosuspend_delay_ms = 15000
+++ Intel Graphics
/sys/class/drm/card0/device/driver = i915
/sys/class/drm/card0/power/rc6_enable = 1 (enabled)
/sys/kernel/debug/dri/0/i915_fbc_status = FBC disabled: pixel format not supported
/sys/kernel/debug/dri/0/i915_edp_psr_status = PSR mode: disabled
/sys/class/drm/card0/gt_min_freq_mhz = 100 [MHz]
/sys/class/drm/card0/gt_max_freq_mhz = 800 [MHz]
/sys/class/drm/card0/gt_boost_freq_mhz = 1000 [MHz]
/sys/class/drm/card0/gt_RPn_freq_mhz = 100 [MHz] (GPU min)
/sys/class/drm/card0/gt_RP0_freq_mhz = 1450 [MHz] (GPU max)
+++ Other Graphics
/sys/class/drm/card1/device/driver = evdi
/sys/class/drm/card2/device/driver = evdi
/sys/class/drm/card3/device/driver = evdi
/sys/class/drm/card4/device/driver = evdi
+++ Wireless
bluetooth = off (software)
nfc = none (no device)
wifi = on
wwan = none (no device)
hci0(btusb) : bluetooth, not connected
wlp170s0(iwlwifi) : wifi, connected, power management = on
+++ Audio
/sys/module/snd_hda_intel/parameters/power_save = 1
/sys/module/snd_hda_intel/parameters/power_save_controller = Y
+++ PCIe Active State Power Management
/sys/module/pcie_aspm/parameters/policy = default performance powersave [powersupersave]
+++ PCIe Runtime Power Management
Enable devices = (disabled)
Disable devices = (disabled)
Device denylist = (disabled)
Driver denylist = (disabled)
/sys/bus/pci/devices/0000:00:00.0/power/control = auto (0x060000, Host bridge, no driver)
/sys/bus/pci/devices/0000:00:02.0/power/control = auto (0x030000, VGA compatible controller, i915)
/sys/bus/pci/devices/0000:00:04.0/power/control = auto (0x118000, Signal processing controller, proc_thermal_pci)
/sys/bus/pci/devices/0000:00:06.0/power/control = auto (0x060400, PCI bridge, pcieport)
/sys/bus/pci/devices/0000:00:07.0/power/control = auto (0x060400, PCI bridge, pcieport)
/sys/bus/pci/devices/0000:00:07.1/power/control = auto (0x060400, PCI bridge, pcieport)
/sys/bus/pci/devices/0000:00:07.2/power/control = auto (0x060400, PCI bridge, pcieport)
/sys/bus/pci/devices/0000:00:07.3/power/control = auto (0x060400, PCI bridge, pcieport)
/sys/bus/pci/devices/0000:00:08.0/power/control = auto (0x088000, System peripheral, no driver)
/sys/bus/pci/devices/0000:00:0a.0/power/control = auto (0x118000, Signal processing controller, intel_vsec)
/sys/bus/pci/devices/0000:00:0d.0/power/control = auto (0x0c0330, USB controller, xhci_hcd)
/sys/bus/pci/devices/0000:00:0d.2/power/control = auto (0x0c0340, USB controller, thunderbolt)
/sys/bus/pci/devices/0000:00:0d.3/power/control = auto (0x0c0340, USB controller, thunderbolt)
/sys/bus/pci/devices/0000:00:14.0/power/control = auto (0x0c0330, USB controller, xhci_hcd)
/sys/bus/pci/devices/0000:00:14.2/power/control = auto (0x050000, RAM memory, no driver)
/sys/bus/pci/devices/0000:00:15.0/power/control = auto (0x0c8000, Serial bus controller, intel-lpss)
/sys/bus/pci/devices/0000:00:15.1/power/control = auto (0x0c8000, Serial bus controller, intel-lpss)
/sys/bus/pci/devices/0000:00:15.3/power/control = auto (0x0c8000, Serial bus controller, intel-lpss)
/sys/bus/pci/devices/0000:00:16.0/power/control = auto (0x078000, Communication controller, mei_me)
/sys/bus/pci/devices/0000:00:16.3/power/control = auto (0x070002, Serial controller, serial)
/sys/bus/pci/devices/0000:00:1d.0/power/control = auto (0x060400, PCI bridge, pcieport)
/sys/bus/pci/devices/0000:00:1f.0/power/control = auto (0x060100, ISA bridge, no driver)
/sys/bus/pci/devices/0000:00:1f.3/power/control = auto (0x040380, Audio device, snd_hda_intel)
/sys/bus/pci/devices/0000:00:1f.4/power/control = auto (0x0c0500, SMBus, i801_smbus)
/sys/bus/pci/devices/0000:00:1f.5/power/control = auto (0x0c8000, Serial bus controller, intel-spi)
/sys/bus/pci/devices/0000:01:00.0/power/control = auto (0x010802, Non-Volatile memory controller, nvme)
/sys/bus/pci/devices/0000:aa:00.0/power/control = auto (0x028000, Network controller, iwlwifi)
+++ USB
Autosuspend = enabled
Device allowlist = (not configured)
Device denylist = (not configured)
Exclude audio = enabled
Exclude bluetooth = disabled
Exclude phones = disabled
Exclude printers = enabled
Exclude WWAN = disabled
Bus 004 Device 001 ID 1d6b:0003 control = auto, autosuspend_delay_ms = 0 -- Linux Foundation 3.0 root hub (hub)
Bus 003 Device 002 ID 27c6:609c control = auto, autosuspend_delay_ms = 2000 -- Shenzhen Goodix Technology Co.,Ltd. Goodix USB2.0 MISC (no driver)
Bus 003 Device 003 ID 8087:0032 control = auto, autosuspend_delay_ms = 2000 -- Intel Corp. AX210 Bluetooth (btusb)
Bus 003 Device 001 ID 1d6b:0002 control = auto, autosuspend_delay_ms = 0 -- Linux Foundation 2.0 root hub (hub)
Bus 002 Device 003 ID 090c:3350 control = auto, autosuspend_delay_ms = 2000 -- Silicon Motion, Inc. - Taiwan (formerly Feiya Technology Corp.) USB DISK (usb-storage)
Bus 002 Device 001 ID 1d6b:0003 control = auto, autosuspend_delay_ms = 0 -- Linux Foundation 3.0 root hub (hub)
Bus 001 Device 001 ID 1d6b:0002 control = auto, autosuspend_delay_ms = 0 -- Linux Foundation 2.0 root hub (hub)
+++ Battery Care
Plugin: generic
Supported features: none available
+++ Battery Status: BAT1
/sys/class/power_supply/BAT1/manufacturer = NVT
/sys/class/power_supply/BAT1/model_name = Framewo
/sys/class/power_supply/BAT1/cycle_count = 145
/sys/class/power_supply/BAT1/charge_full_design = 3572 [mAh]
/sys/class/power_supply/BAT1/charge_full = 3072 [mAh]
/sys/class/power_supply/BAT1/charge_now = 3047 [mAh]
/sys/class/power_supply/BAT1/current_now = 635 [mA]
/sys/class/power_supply/BAT1/status = Discharging
/sys/class/power_supply/BAT1/charge_control_start_threshold = (not available)
/sys/class/power_supply/BAT1/charge_control_end_threshold = (not available)
Charge = 99.2 [%]
Capacity = 86.0 [%]
