[SOLVED] Status of Fingerprint Reader on Mint?
What is the status of getting the fingerprint reader to work in Linux Mint? To date I have not been able to get it working and I cannot find much discussion of this.
FW 13 DIY
Serial: FRANBMCPAB1443024T
Host: Laptop AB
BIOS: INSYDE Corp. 3.17 (10/27/2022)
OS: Linux Mint 21.2 x86_64
DE: Cinnamon 5.8.4 (x11)
Kernel: Linux 5.15.0-78-generic
Shell: bash 5.1.16
WM: Mutter (Muffin)
CPU: 11th Gen Intel i7-1165G7 (8) @ 4.7GHz
GPU: Intel TigerLake-LP GT2 [Iris Xe Graphics]
GPU Driver: i915
Memory: 4.81 GiB / 15.40 GiB (31%)
Disk (/): 43G / 228G (20%)
Network: Wifi6
Bluetooth: Intel Corp. AX210
I have replaced Cinnamon with Gnome (DE: GNOME 42.9 (x11)) and now the fingerprint option appears in Settings>Users>Fingerprint Login. Even though I have enabled FP login the prompt does not appear at Login or with sudo… I have tried using my fingerprint even without the prompt but it is not recognized.
Holy Moses! I have got the FP reader to work on Linux Mint with Gnome. First, I replaced Cinnamon with the latest Gnome. (I suspect that the FP is dependent upon Gnome.) After reboot I was allowed to enroll a fingerprint in Settings>Users>Fingerprint Login, and rebooted again, but still there was no FP action allowed. After poking around in other threads I came across this command: sudo pam-auth-update. Ran it and in the PAM Configuration box I made sure that Fingerprint Authentication line was checked and then hit OK. After reboot I now have FP at login and for sudu.
Host: Laptop AB
Shell: bash 5.1.16
WM: Mutter
GPU Driver: i915
Memory: 2.79 GiB / 15.40 GiB (18%)
Disk (/): 49G / 228G (23%)
Network: Wifi6
Not sure if its anywhere else but…
sudo apt install libpam-fprintd
select fingerprint authentication and OK
Then enroll a finger or 3
fprintd-enroll -f (finger)
• left-thumb
• left-index-finger
• left-middle-finger
• left-ring-finger
• left-little-finger
• right-thumb
• right-index-finger
• right-middle-finger
• right-ring-finger
• right-little-finger
Thanks to @Malcolm_Spiller this worked first time for me in LM22 Cinamon, thanks for sharing,
@Malcolm_Spiller does this require the user to replace Gnome as @QRP did?
Running cinnamon myself so I afraid I don’t know
no, should work on cinnamon or gnome. It doesn’t work on first login, apparently because the keyring isn’t unlocked - it attempts to log in then kicks you back to the login screen - it might be possible to just replace lightDM with gdm - I haven’t played with it yet.
Waiting for it to time out, or using the wrong finger, will prompt you for a password and you can log in. After that you can use your fingerprint for sudo, updates, etc.
@Malcolm_Spiller It does not require Gnome to be replaced. Thanks for sharing the commands!
