Earlier while I was using my Framework Laptop 16 I got jumpscared by an extremely loud, continuous screeching noise. I thought the building’s fire alarm went off until I left my apartment and realized it was inside. I wrote down later that it sounded like a low siren or a turbine. The frequency would sometimes shift around, though not on a regular cycle. I know that the obvious lead is the fans; I want to make it clear that I’ve heard computer fans at full power before and this was much louder.
I scrambled for some 2 minutes trying to figure out the source as I have quite a few devices on my desk. I unplugged the main power strip (to no effect) before realizing the Framework Laptop 16 was the cause. I disconnected all peripherals which eventually stopped the noise as unplugging both displays while the laptop’s lid was closed (which is how I normally use it) puts it to sleep.
I know sleep mode is relevant because I later opened the lid back up and the noise restarted instantly. This means the noise was happening while the computer was on battery without anything plugged into it. At that point I was genuinely concerned about fire risks and pressed the power button, which shut it down normally.
Throughout the entire episode the system kept running, with both external displays and the internal one working when they should, and I made no note of anything looking wrong with the OS. Although I do not remember using any input device other than the power button. I also wrote down that the computer was not particularly hot and the case did not shock me when I inevitably touched it (at least nothing out of the ordinary).
Needless to say, this scared the shit out of me and I’m now genuinely afraid to turn it back on, which is not the kind of first experience I was counting on today ![]()
Frustratingly, I don’t have any video or audio recording. As I’m sure you’ll understand, I was dead focused on stopping the literal alarm.
When this happened I had just connected the jack to my headphones (jack is always connected on the laptop side but I often disconnect it on the headphones side to use Bluetooth) and I was in pavucontrol about to switch the audio output there instead of speakers (my config is wonky so it doesn’t switch automatically). This is something I do all the time. In case this is relevant, I want to reiterate that unplugging the computer side of the jack did nothing about the noise while it was happening.
I’ve now taken the hard drive out (fsck is happy, which is at least something) for extra backups and restoring my system on another machine, from which I’m writing this post. I will try to get some logs out. I’m considering removing the battery and trying to use the Framework Laptop 16 again but I’d rather have some opinion first on how that noise could happen and if there is any danger.
Machine details: Ryzen 7 7840HS, BIOS version ??, no external graphics card
System details: Arch (last updated a week ago), latest kernel
Peripherals at the time of the incident (been using this setup for months):
- Back left HDMI adapter to external display
- Middle left DP adapter to external display
- Front left USB-A hub with one device plugged in, turned off
- Back right USB-C charger
- Middle right Jack (connected)
- Front right USB-A mouse
- Charger plugged in, battery fully charged (I have used the laptop on battery recently and even allowed the battery to empty completely on accident a few days ago)
- Lid closed
