I have a Framework 13 which has had a few upgrades (mainboard, screen, battery etc). It is a few years old by now! In general, I’ve been happy with the hardware and build quality.
Over the past month though, the front edge of the frame - specifically the area across just between the outer edge and the trackpad - has been lifting. The front corners are fully seated but the space across the trackpad is now flexing quite a lot.
~June 9th
Today (I put a short video showing the flex on Dropbox)
- Are other people seeing similar issues? Any clues to what might cause this?
- What replacement part should I be looking at?
- Is the upper part of the case for the new Pro models compatible?
Thanks!
