Speaker Malfunction Randomly
Every once in a while, while watching a video or playing music, the speakers will drop to a weird low-volume tinny sound. Usually some light percussive maintenance will fix it, so I think maybe it’s a loose connection?
I don’t know if anyone knows about common weak points that might be causing it?
Thank you!
OS: Windows 11
Device: 16 with AMD 7040, Fan bay module
try to toogle energy saver mode in windos, helped me
