During general light usage of my laptop, the battery seems to drain at nearly the same rate as the included charger can charge it. Is this expected drain, or should I investigate to see if something else is up? Attached is the battery information. Pay attention to the latest dip and the timeframe for it. I am not using any heavy 3d applications, only light Chrome tabs, Discord, and sometimes MRD. I have the lowest tier i5 board if that helps.
I do not have the same issue, however I am having horrible battery drain, like 1% a minute.
At first I thought Windows 11 was running great on the Framework, but I started getting all kinds of problems, with the biggest one being that if I suspended or hibernated, my session was just gone when I resumed and it appeared as though I did a cold boot.
Back on Windows 10 and everything works. I’m good with that, and will give Windows 11 time to improve.
This looks a lot like Windows 11 BSoD: Bug Check 0x9F, since it’s a bugcheck on sleep and other power transitions that impacts any SST users on any version of Windows 11.
