Struggling to reset keyboard to defaults after using configurator
I used the configurator and accidentally cleared fn and the super key. I know the super key was labeld Lwin but I can’t find it anywhere in the website. I don’t remember what fn was but I doubt it’s there either. I do not see a reset to factory default option anywhere in the website. Where can I download the default config and flash it with QMK? At least that’s what I think needs to be done unless there is a tool to reset the config without doing that.
edit fixed by flashing erase UF2 then ansi UF2
