I was talking to support about an issue and I needed to remove the right side panel, but I’m not able to get it removed based on the guide they sent me: Side Panels - Framework Guides
If I would apply more force, I might break something. And I don’t want to go that far if I might need to send it back.
Overall, the left panel also was a bit harder to remove already, but way easier.
Does anyone else of you have that issue and solved it? Or do you really need to remove something else other than the top and the front panel?
I felt the same but just gripped it from the top, applied pressure and kept pulling up with my fingers until it popped out. I felt like I was going to break it too but it eventually just slid up.
I had the same issue. I ended up using a thin, but relatively wide flat screwdriver tip inserted in between the silver bottom piece and the side panel. Gently rotating the screwdriver a little tiny bit at one end and then the other caused the panel to visibly lift a millimeter or so. That was all it needed: it popped off by hand after that. But be careful twisting the screwdriver or else you will dent the plastic. Maybe there is a plastic tool for doing things like that.
Nothing else you need to do, you just really need good grip on the panel - I had the issue myself, actually already struggled with the top panel at first - using a rubbery glove even the right panel came off at once without much force required.
I used a thin plastic spatula to wiggle between the front corner at the bottom by the silver base and gently slid it toward the back of the machine. Was super simple once I figured this out.
When I first held the device and marbled at it, the front panel came flying off and I thought I had broken something. Glad I was able to recover quickly catch it midair before the desktop hit the tile floor but even then it’s probably not a big deal.
