What memory brands and models are supported with the laptop? I am looking to get 2x8GB
Anything should do, stay with 3200mhz and must be a sodimm.
Couple good sets for cheaper than framework
Crucial 16GB (2 x 8GB) 260-Pin DDR4 SO-DIMM DDR4 3200 (PC4 25600) Laptop Memory Model CT2K8G4SFRA32A - Newegg.com $81.40
Team Elite 16GB (2 x 8GB) 260-Pin DDR4 SO-DIMM DDR4 3200 (PC4 25600) Laptop Memory Model TED416G3200C22DC-S01 - Newegg.com $79.99
Some discussion here: Memory Support specs?
Of note, with the current BIOS at least the laptop doesn’t support XMP so be sure the RAM can run at its rated speed without XMP.
In particular the Ballistix 3200MHz 2x16GB (BL2K16G32C16S4B) kit only runs at 2667MHz.
