Timing on refilling Antenna Module for 13
  • Which OS (Operating System)? 11 pro
    • Framework laptop (13th generation Framework laptop) are you asking for support with? WIfi antenna module. I was installing my new 13 gen i7 and I squished the plugs on my Antenna Module for the 13.
Any updates on when they will be back in stock?
Thanks Mikael
Are you sure you’re looking at the right module? The Intel ones available on the store appear in stock to me. It looks to me like it’s just the AMD module that hasn’t been stocked yet. If they’re indeed out, you can also consider buying the module elsewhere - it’s a standard piece and not something Framework specific.
only chromebook is in stock. I squished the 2 plugs on my cable not the card.
Contact support and see if they can find any stock internally or when a restock is likely.
@mikael_jordan Although not optimal or cost efficient, you could purchase a new top cover which has the antenna module pre-installed.
Scott,
Thanks, for the info but I just ordered new cables and a micro antenna until i hear back.
