I, too, have encountered this recently. Running on battery ~65% when it happened. Rebooted and went back to it (was watching a movie). Windows 10 event log showed a power loss, no long press detected, and nothing else leading up to that.
I had only a set of earbuds connected.
Expansion cards:
2x USB-C
1x USB-A
1x MicroSD Reader (empty)
Specs:
Diy edition i5
2x 8gb ram
1tb sn750
firmware 3.07
wifi ax 210 (no vpro)
has anyone that has contacted support on this issue reached a resolution?
This was also the solution for me under a Linux OS. one of my RAM sticks was bad. I setill experience this crash/sudden power loss occasionally but its now less frequent and appears to be related to mouse input during wake (which is probably a topic for another thread)
I had this happen to me once as well. I’ve contact support and they’ve asked for a video of the computer booting. For the record I ordered late enough to not be in the batch system, i5, Windows 11 DIY with 1TB Intel SSD and 16GM RAM (Dual 8GB).
The same thing just happened to me for the first time.
I was in a meeting reading information off of my laptop screen, the laptop was on battery with over 60% charge. The laptop just turned itself off. After a few seconds I pressed the power button and the computer turned back on.
I hope it will not happened again!
Got my 11th gen (i7-1165G7) framework a few weeks ago, just had my first random poweroff at ~62% battery. Instant shutoff under low cpu load (just browser idle and playing a very low-resource game (dungeon crawl stone soup)).
I will run another memtest overnight; first one passed, but memory faults can take several tries to find if they exist.
My operating system is OpenBSD, I have the sysctls machdep.pwraction=0 (do nothing on pressing power button), and machdep.lidaction=1 (suspend on lid close) set, so I doubt it’s anything intended OS side if it is in fact a software bug. Nothing in the syslog that helps, just normal daemon messages and the message for the next boot.
I am also on the latest bios revision (03.07 iirc), I also was touching the touchpad when the shutoff happened, and I was not touching the keyboard. Palms were resting on the palm rest.
I assume you got the DYI version. I had random shutoffs all the time. I got it to stop once I removed 1 of my 2 ram sticks. Your mileage may vary. I suggest contacting customer support.
Are all the relevant drivers loading at boot - pchgpio, iic, dwiic, ihidev, imt? You might compare your dmesg output with this post from the OpenBSD mailing list. If you have:
this happened to me yesterday when I was editing a document on the train (on battery). Screen went entirely blank and nothing in event viewer other than “the previous shutdown was unexpected”.
This is the first time I’ve seen it happen but I suspect it’s been happening when Windows does the suspend-to-hibernate thing, as sometimes I will start up my laptop having put it to sleep the day before and none of my programs will be open. Same situation in Event Viewer.
My config is the i5-1135G7, 1x 8GB RAM, 1TB WD SN750, Windows 10, bios 3.07
Instant power loss while watching something (HDMI → TV and aux cable → amplifier). Batch 5, i5, Fedora 36 KDE (just updated from 35 today). Laptop not plugged into wall, battery at ~65%, no active interaction with keyboard to rest of laptop so no fn keys being pressed. Laptop wasn’t hot to the touch, no fan whirring.
journalctl logs say:
Sep 18 10:51:17 fedora plasmashell[6268]: libva info: Trying to open /usr/lib64/dri/iHD_drv_video.so
Sep 18 10:51:17 fedora plasmashell[6268]: libva info: Found init function __vaDriverInit_1_14
Sep 18 10:51:17 fedora plasmashell[6268]: libva info: va_openDriver() returns 0
Sep 18 10:56:43 fedora org_kde_powerdevil[2620]: org.kde.powerdevil: Unsatisfied policies, the action has been aborted
Sep 18 10:57:58 fedora org_kde_powerdevil[2620]: org.kde.powerdevil: Unsatisfied policies, the action has been aborted
...aaaand power loss.
Can’t figure out what powerdevil wanted to do - power settings don’t call for sleep or shutdown or even screen dimming.
Going to assume it’s a hardware issue…as the issue wasn’t unexpected graceful system shutdown…but an instant power loss.
If that’s the case, then one ‘typically’ likely (read with a pinch of salt) cause is the cells in the battery pack are not as well balanced as they should be (actual charge / capacity wise).
What you can typically do is to give the laptop a few charge / discharge cycles just to ‘freshen’ up the pack. Sometimes, that’s all it takes to back the battery pack back onto the happy path. If the issue persists…reach out to support.
I’ve been experiencing random shut offs since I got my framework laptop a week ago (batch 3 12th gen). While typing it will shutoff instantly. Wakes up as if from hibernate. Some relevant event viewer text below (laptop died in use at 3:25, made sure to wait and turned it on at 3:50). “Button or lid” seems to be the reason.
Log Name: System
Source: Microsoft-Windows-UserModePowerService
Date: 10/1/2022 3:50:31 PM
Event ID: 12
Task Category: (10)
Level: Information
Keywords:
User: SYSTEM
Computer: serkanframework
Description:
Process C:\Windows\System32\WUDFHost.exe (process ID:1380) reset policy scheme from {381b4222-f694-41f0-9685-ff5bb260df2e} to {381b4222-f694-41f0-9685-ff5bb260df2e}
Event Xml:
<Event xmlns="http://schemas.microsoft.com/win/2004/08/events/event">
<System>
<Provider Name="Microsoft-Windows-UserModePowerService" Guid="{ce8dee0b-d539-4000-b0f8-77bed049c590}" />
<EventID>12</EventID>
<Version>0</Version>
<Level>4</Level>
<Task>10</Task>
<Opcode>0</Opcode>
<Keywords>0x4000000000000000</Keywords>
<TimeCreated SystemTime="2022-10-01T22:50:31.7662385Z" />
<EventRecordID>5045</EventRecordID>
<Correlation />
<Execution ProcessID="1096" ThreadID="14964" />
<Channel>System</Channel>
<Computer>serkanframework</Computer>
<Security UserID="S-1-5-18" />
</System>
<EventData>
<Data Name="ProcessPath">C:\Windows\System32\WUDFHost.exe</Data>
<Data Name="ProcessPid">1380</Data>
<Data Name="OldSchemeGuid">{381b4222-f694-41f0-9685-ff5bb260df2e}</Data>
<Data Name="NewSchemeGuid">{381b4222-f694-41f0-9685-ff5bb260df2e}</Data>
</EventData>
</Event>
Log Name: System
Source: Win32k
Event ID: 701
Task Category: None
Level: Warning
Keywords: Classic
User: N/A
Description:
Power Manager has not requested suppression of all input (INPUT_SUPPRESS_REQUEST=0)
Event Xml:
<System>
<Provider Name="Win32k" />
<EventID Qualifiers="32768">701</EventID>
<Level>3</Level>
<Task>0</Task>
<Opcode>0</Opcode>
<Keywords>0x80000000000000</Keywords>
<TimeCreated SystemTime="2022-10-01T22:50:31.5277076Z" />
<EventRecordID>5044</EventRecordID>
<Correlation />
<Execution ProcessID="4" ThreadID="1840" />
<Security />
</System>
<EventData>
<Data>
</Data>
<Binary>000000000100000000000000BD020080000000000000000000000000000000000000000000000000</Binary>
</EventData>
</Event>
Log Name: System
Source: Win32k
Event ID: 701
Task Category: None
Level: Warning
Keywords: Classic
User: N/A
Description:
Event Xml:
<System>
<Level>3</Level>
<Task>0</Task>
<Opcode>0</Opcode>
<EventRecordID>5043</EventRecordID>
<Correlation />
<Security />
</System>
<EventData>
<Data>
</Data>
</EventData>
</Event>
Log Name: System
Source: Microsoft-Windows-Kernel-General
Event ID: 1
Task Category: (5)
Level: Information
Keywords: Time
User: N/A
Description:
The system time has changed to 2022-10-01T22:50:31.500000000Z from 2022-10-01T22:25:48.757061000Z.
Time Delta: 1482742 ms
Change Reason: System time synchronized with the hardware clock.
Process: '' (PID 4).
RTC time: 2022-10-01T15:50:31.500000000Z
Current time zone bias: 420
RTC time is in UTC: false
System time was based on RTC time: false
Event Xml:
<System>
<Provider Name="Microsoft-Windows-Kernel-General" Guid="{a68ca8b7-004f-d7b6-a698-07e2de0f1f5d}" />
<EventID>1</EventID>
<Version>4</Version>
<Level>4</Level>
<Task>5</Task>
<Opcode>0</Opcode>
<Keywords>0x8000000000000010</Keywords>
<TimeCreated SystemTime="2022-10-01T22:50:31.5002524Z" />
<EventRecordID>5042</EventRecordID>
<Correlation />
<Execution ProcessID="4" ThreadID="13260" />
<Security />
</System>
<EventData>
<Data Name="NewTime">2022-10-01T22:50:31.5000000Z</Data>
<Data Name="OldTime">2022-10-01T22:25:48.7570610Z</Data>
<Data Name="TimeDeltaInMs">1482742</Data>
<Data Name="Reason">2</Data>
<Data Name="ProcessName">
</Data>
<Data Name="ProcessID">4</Data>
<Data Name="CmosTime">2022-10-01T15:50:31.5000000Z</Data>
<Data Name="TimeZoneBias">420</Data>
<Data Name="RealTimeIsUniversal">false</Data>
<Data Name="SystemInCmosMode">false</Data>
</EventData>
</Event>
Log Name: System
Source: Microsoft-Windows-Kernel-Power
Date: 10/1/2022 3:25:48 PM
Event ID: 107
Task Category: (102)
Level: Information
Keywords: (1024),(64),(4)
User: N/A
Description:
The system has resumed from sleep.
Event Xml:
<System>
<Provider Name="Microsoft-Windows-Kernel-Power" Guid="{331c3b3a-2005-44c2-ac5e-77220c37d6b4}" />
<EventID>107</EventID>
<Version>1</Version>
<Level>4</Level>
<Task>102</Task>
<Opcode>0</Opcode>
<Keywords>0x8000000000000444</Keywords>
<TimeCreated SystemTime="2022-10-01T22:25:48.7523664Z" />
<EventRecordID>5041</EventRecordID>
<Correlation />
<Security />
</System>
<EventData>
<Data Name="TargetState">5</Data>
<Data Name="EffectiveState">5</Data>
<Data Name="WakeFromState">5</Data>
<Data Name="ProgrammedWakeTimeAc">1601-01-01T00:00:00.0000000Z</Data>
<Data Name="ProgrammedWakeTimeDc">1601-01-01T00:00:00.0000000Z</Data>
<Data Name="WakeRequesterTypeAc">0</Data>
<Data Name="WakeRequesterTypeDc">0</Data>
</EventData>
</Event>
Log Name: System
Date: 10/1/2022 3:25:47 PM
Event ID: 42
Task Category: (64)
Level: Information
Keywords: (1024),(4)
User: N/A
Description:
The system is entering sleep.
Sleep Reason: Button or Lid
Event Xml:
<System>
<EventID>42</EventID>
<Version>3</Version>
<Level>4</Level>
<Task>64</Task>
<Opcode>0</Opcode>
<Keywords>0x8000000000000404</Keywords>
<TimeCreated SystemTime="2022-10-01T22:25:47.8842305Z" />
<EventRecordID>5040</EventRecordID>
<Correlation />
<Security />
</System>
<EventData>
<Data Name="Reason">0</Data>
<Data Name="Flags">0</Data>
<Data Name="TransitionsToOn">27</Data>
</EventData>
</Event>
Log Name: System
Date: 10/1/2022 3:25:45 PM
Event ID: 12
Task Category: (10)
Level: Information
Keywords:
User: SYSTEM
Description:
Event Xml:
<System>
<Level>4</Level>
<Task>10</Task>
<Opcode>0</Opcode>
<TimeCreated SystemTime="2022-10-01T22:25:45.9086802Z" />
<EventRecordID>5039</EventRecordID>
<Correlation />
<Execution ProcessID="1096" ThreadID="16388" />
</System>
<EventData>
</EventData>
</Event>
Log Name: System
Source: Win32k
Event ID: 700
Task Category: None
Level: Warning
Keywords: Classic
User: N/A
Description:
Power Manager has requested suppression of all input (INPUT_SUPPRESS_REQUEST=1)
Event Xml:
<System>
<EventID Qualifiers="32768">700</EventID>
<Level>3</Level>
<Task>0</Task>
<Opcode>0</Opcode>
<TimeCreated SystemTime="2022-10-01T22:25:45.8583544Z" />
<EventRecordID>5038</EventRecordID>
<Correlation />
<Execution ProcessID="4" ThreadID="5312" />
<Security />
</System>
<EventData>
<Data>
</Data>
<Binary>000000000100000000000000BC020080000000000000000000000000000000000000000000000000</Binary>
</EventData>
</Event>
Log Name: System
Source: Win32k
Event ID: 700
Task Category: None
Level: Warning
Keywords: Classic
User: N/A
Description:
Event Xml:
<System>
<Level>3</Level>
<Task>0</Task>
<Opcode>0</Opcode>
<EventRecordID>5037</EventRecordID>
<Correlation />
<Security />
</System>
<EventData>
<Data>
</Data>
</EventData>
</Event>
Log Name: System
Event ID: 566
Task Category: (268)
Level: Information
Keywords: (1024),(512),(4)
User: SYSTEM
Description:
The system session has transitioned from 56 to 57.
Reason WinRT
BootId: 6
Event Xml:
<System>
<EventID>566</EventID>
<Level>4</Level>
<Task>268</Task>
<Opcode>0</Opcode>
<Keywords>0x8000000000000604</Keywords>
<TimeCreated SystemTime="2022-10-01T22:25:45.8359049Z" />
<EventRecordID>5036</EventRecordID>
<Correlation />
</System>
<EventData>
<Data Name="BootId">6</Data>
<Data Name="Reason">25</Data>
<Data Name="PreviousSessionId">56</Data>
<Data Name="PreviousSessionType">0</Data>
<Data Name="PreviousSessionDurationInUs">323007545</Data>
<Data Name="PreviousEnergyCapacityAtStart">28274</Data>
<Data Name="PreviousFullEnergyCapacityAtStart">53992</Data>
<Data Name="PreviousEnergyCapacityAtEnd">27135</Data>
<Data Name="PreviousFullEnergyCapacityAtEnd">53992</Data>
<Data Name="NextSessionId">57</Data>
<Data Name="NextSessionType">3</Data>
<Data Name="PowerStateAc">false</Data>
<Data Name="MonitorReason">25</Data>
</EventData>
</Event>
Wow you were right, my chromebook sits right next to my laptop and it has a really strong magnet. If I move my framework close to the laptop the framework will shut off. Thank god its not an actual issue then! Thanks
Another one to add to the list. In my case, it was just sitting there idling with the lid closed for nearly a day.
AC plugged in. 80% battery. No event log messages aside for “The previous system shutdown was unexpected.” No BSOD. No dumps. Nothing. System died as if someone powered it off.
12th Gen DYI - 3rd Batch, but I purchased their memory.
Whatever this is hasn’t been fixed. Using a 12th gen i7-1260P. I was on battery around 85% with a little bit of WebGL going and it instantly powered off mid-keystroke with no logs. I was nowhere near max TDP and had minimal disk usage but notably using the GPU.
I’m running Arch with the beta 3.06 BIOS, so this isn’t a windows-only thing. My power settings are tuned for savings, with some cores turned off when not in use, turbo disabled on battery, etc.
Putting my engineer hat on for a second, I’d guess it is a power management problem for the CPU/GPU package in response to big spiky demand changes. I’ve seen other machines, notably desktop GPUs have brownouts and their VRM regulation algorithms needed tweaks in firmware.
