UI glitches in KDE
  1. Linux Fedora.
  2. 42 beta
  3. Laptop 13, AMD 7840U
    I have UI on screen bottom on every KDE based distribution. I checked Kubuntu 24.04, 24.10, 25.40 beta and Fedora KDE Edition 41 and 42 beta.
    IMG_1101-2
I don’t see any glitch but if your referring to the panel sometimes “floating” and not, that’s intentional. You can disable it by have it float always ( that’s how I’ve configured it ) or not always float
If I remember right, if no windows are showing, the panel doesn’t float otherwise it does. I set mine to always float no matter the state of the windows.
right click on the panel and select “Show Panel Configuration”
These are my settings
No, I marked artifacts by arrows.
I think I found related KDE bug. As workaround I set 200% scale and problem is gone.
ok, I didn’t see/notice that
