(USB?) Microphone does not work on Bazzite KDE
I got my Framework 13 AI 7 350 in yesterday, and installed Bazzite KDE (switching to Linux for the first time in 12 years). I am used to windows (and SteamOS on my livingroom gaming PC), and bazzite seemed like the most friendly solution.
After updating the kernel, and installing the software I need, I found out that the Microphone does not work. I tried my Bluetooth earbuds, and the microphone on those does work. Then I tried an external USB microphone, which does not work either.
In the system settings and audacity it shows the Family 17h/19h/1ah HD Audio Controller (headset mono and the digital microphone)
I installed a camera application, which shows Digital Microphone and ALC285 Analog.
Neither Audacity nor the Camera app seem to record audio using the default mic or the usb c mic. Recording did work when I used my bluetooth earbods.
I made sure that the physical switch is on (aka, the orange is not visible)
Is there anyone where who knows what the issue might be? I imagine something driver related.
I really like the laptop so far and look forward to use it as one of my daily drivers :slight_smile:
System Settings
Operating System: Bazzite 43
KDE Plasma Version: 6.5.3
KDE Frameworks Version: 6.20.0
Qt Version: 6.10.1
Kernel Version: 6.17.7-ba20.fc43.x86_64 (64-bit)
Graphics Platform: Wayland
Processors: 16 Ɨ AMD Ryzen AI 7 350 w/ Radeon 860M
Memory: 32 GiB of RAM (30.6 GiB usable)
Graphics Processor: AMD Radeon 860M Graphics
Manufacturer: Framework
Product Name: Laptop 13 (AMD Ryzen AI 300 Series)
System Version: A7
Issue resolved after talking to customer support
Internal mic:
was a cable issue. reseating it fixed it
External USB mic:
seems there is some compatibility issue with the EPOS expand capture 5 and Linux.
tried another USB microphone (blue snowball) at home which works fine.
Having the same issue with a bluetooth headset. Last night I did a fresh install* (and moved from bazzite gnome to kde) and I’m still having the same problem.
Did you try a system update and restart? I have not had any issues with Bluetooth headphones, and the EPOS microphone started working as well
+1 to this issue, did you ever find a fix?
