USB speed on AMD board
(1): USB 4
(2): USB 3.2
(3): USB 4
(4): USB 3.2
The USB 4 are 40 Gbps, but what about the USB 3.2, are they 3.2 gen 2x2 (20 Gbps)?
Refer to the second last paragraph in the first post:
Plus this:
https://www.usb.org/usb-32-0#:~:text=USB%203.2%20identifies%20three%20transfer,rate%2C%20without%20sacrificing%20cable%20length
And this:
https://www.usb.org/sites/default/files/usb_data_performance_language_usage_guidelines_june_2023.pdf
According to the guideline:
“Vendors must clearly communicate the performance signaling that a product delivers in the product’s packaging, advertising content, and any other marketing materials.”
FB Marketplace page:
So, it seems like the performance signaling of the product is not communicated in accordance to the ‘guideline’. (Guideline isn’t something that is a must, but best to follow)
They’re 10Gbps ports, AMD publishes the ports & speed on their tech specs.
AMD Ryzen™ 7 7840U | AMD
Thanks @Second_Coming and @Water261
