I’m having a very strange issue with the system clock on my Framework 16 that I got just before Christmas. It’s a dual boot Ubuntu/Windows 11 23h2 install. If I boot into Windows the system time in Windows is accurate. However, if I boot into Linux and THEN reboot into Windows 11 the clock in Windows will be way off until I reset it. Time in Linux is always ok. What’s up here?
This issue actually happens on any Ubuntu/Windows dual-boot system, and there’s several threads about it already, here’s a quick answer for you:
You can edit a registry file on Windows. Use a text editor to input the following, then rename the file format to .reg
RealTimeIsUniversal.reg
Windows Registry Editor Version 5.00
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\TimeZoneInformation]
“RealTimeIsUniversal”=dword:00000001
Then run it
