I’ve had my Framework 13 for about 6 months now and have loved it. But over time I’ve noticed when it’s pitch quiet that the laptop makes some weird but very quiet electronic jittering noises. I was curious what this could be and if it is something I should look out for or if it is normal.
It could be a coil wine. What CPU do you have? I recall having seen something regarding AMD chips, but I do not remember which version.
It might be coil wine. I have the Ryzen 7640U chip. My previous laptop was a Ryzen 7735U but didn’t make any noises.
I recall seeing something, somewhere about a coilwine/noise on the Ryzen 7000 chips. When I have more time I will check and report back. Did you send a message to support about it?
I haven’t asked this is the first time I’m asking about it
To my understanding, the design of the motherboard, and the power delivery components specifically, affects how much coil-whine a device may have - but it also varies from unit to unit. (Maybe due to minor manufacturing/component variance?) I have a FW13 AMD 7840U for 2 years now, and I’ve never noticed coil whine. Sorry if that’s not much help ![]()
I haven’t noticed any performance issues and I’ve had the laptop for 7 months now, if anything I’ve noticed the battery life improve a lot after some firmware updates. The sound is hardly noticeable unless I am in a dead quiet area and put my ear close to the laptop. I was just trying to ensure this isn’t something to be concerned about.
