I’d like a transparent or dark blue one.
@Vaelatern What no “other” option? My preferred is not on your list.
Here you go (again, choose up to 4):
- See first poll - My choice is there
- Dark Blue
- Animal Print
- Checkerboard
- Some other pattern
- Other
0 voters
Bringing up bezel color options again, with all the LTT fans who bought a Framework laptop, perhaps a limited edition LTT orange bezel would be a neat option (in the same vein as the similar LTT orange limited edition Noctua fans from a few years ago).
I’d love the LTT bezel, as well as perhaps a dark navy option
Use me as a voting bank if you want Silver Bezel.
I want my framework laptop to match it’s bezel color with the body color, just as the old macbook air. And white bezels can not replicate that effect.
Please bring Silver Bezel, and people, like here to show your support for this change.
Yes, I’ve always thought they should have a silver bezel, I’m surprised they don’t. I’m torn between silver and black, I like both and they are the standard. Still, I like my black bezel. I considered getting a white one and spraying it silver, but I’m not sure I could be bothered removing the sliding doors in case I ruined it. I’m sure I could manage, but it would be much easier to purchase a silver one to begin with.
Red ![]()
Mirror-polished chrome so that you can see if someone’s snuck up behind you.
Purple everything
It’d be too difficult to properly apply mirror tape across the entire bezel, especially given that it is flexible. There would be bubbles and creases unless the tape is quite rigid, but if it’s quite rigid, it will be difficult to use a razor to cut it to match the bezel.
Better to have it applied by the manufacturer and die cut.
But I was referring to a metal bezel that is then chrome-plated and polished. The metal would add to rigidity of the display lid.
That’s one of the best things about Framework: the ability to easily customize/personalize the laptop to one’s own preferences!
I happen to like shiny/glossy screens; the chrome/mirror won’t bother me.
Not sure if there’s a connector to power it, but an RGB LED bezel.
Computer needs more bling.
Guess it wouldn’t be too hard to put gold leaf on the bezel, but I think it would look a bit too bling.
As stated in topic, clear bezel to match clear keyboard.
