What is the best WIFI module/pcie card for the mainboard strix halo 395 ryzen?
While waiting for my 2 x strix halo motherboard, I’m researching what is the best wi-fi module or wi-fi pcie slot based card to achieve optimal wifi speeds (I did not purchase a module yet).
I’ve seen posts for laptops but did not find anything about the desktop mainboard.
So guys, what do you recommend? (wifi 7+, good card)
It does not have to be the most expensive, maybe in the price range of 40-120$ max?
Thanks.
Bump?
i tested be200 doesnt work ! ax210 stable but no wifi7 ! best so far qualcom QCNCM865 !! very happy with this !
Is the connection stable? Is this the best option? How are the pcie 4 x 4 cards? Anyone tested them?
The connection is stable. As I said, I’m very satisfied! I haven’t tested PCIe x4 cards. All the modules I tested were M.2! The AX210 is stable, but only with Wi-Fi 6e. The Qualcomm is stable with Wi-Fi 7.
@inteks Thanks! Very helpful!
What speeds are you getting?
