Hey, just got my Framework and I’ve had a couple hiccups,
My first problem is the Wifi Antenna, It doesn’t seem to be working, The connectors are… well connected (I think) and the card is seated properly. When in windows, It says the drivers aren’t installed, no clue how to fix that.
Second problem, My right click isn’t working, tried two finger tap, bottom corner, nothing seems to work, also scrolling doesn’t work?
