WiFi connection unreliable
I’m using Ubuntu.
Which release version?
22.04 LTS
Which kernel are you using?
Which Framework Laptop 13 model are you using? (AMD Ryzen™ 7040 Series, Intel® Core™ Ultra Series 1, 13th Gen Intel® Core™ , 12th Gen Intel® Core™, 11th Gen Intel® Core™)
which model you have?
Intel or AMD?
If is a AMD one, the original MediaTek WiFi card is a pile of crap, especially on Linux, you can replace it with a Intel AX210 non-vpro and you will be fine.
My mediatek wifi & bluetooth card has worked fine from day one. I have had absolutely no problems with it. To make the sweeping claim that these are crap on a sample of one is rather extreme.
Thanks, I do and that’s very helpful.
Ubuntu 24.10, latest stable kernel and bios in amd 7840u, fw 13 and i have not encountered any wifi problems.
Is not a sample of 1, in my case is a sample of 3 from different laptop brands( Framework, Asus and Lenovo).
if you look here in the forums, there are more examples.
The MediaTek issues seems to be worse with WiFi6/6E APs.
Those MediaTek WiFi cards without issues is the exception, if you Google it you’ll see.
Regarding it’s Bluetooth, you are correct it works (mouse and BT Audio).
remember that for a communication to happen, you need 2 peers.
If one peer is bad, the other will have issues too.
From experience, Wifi 6 is a real PITA as not really well established yet.
I bet they will fix all the incompatibilities over time, but I tend to stick to regular WiFI in the meantime.
Note also, that WiFi 6 makes sense when you are in the same room with no walls in between only.
When I say WiFI6 I mean the AX standard, that have a night and day difference in comparison to the older AC and N standards. On My case I use both 5GHz and 6GHz bands, nowadays 2.4GHz is unusable in any place that is not a isolated house or farm.
When I was using the MT WiFi card I could see “micro drops” in the connection (you can check with wavemon), that was cutting the apparent performance when browsing. After replacing it, now it feels 2-3x faster.
This is on a dual band (5 and 6 GHz) pure WiFi6, without any legacy devices (they all are in a different AP, for performance reasons).
Well, I’d run the device in debugging mode to see what the issues are.
And, every wifi device has its own debugging mode :frowning:
