11th gen not powering on
Hi, yesterday my 11 gen Framework i7-1165g7 (Windows 11) died on me while watching YouTube and updating Linux VM on the background.
Tried to turn it back on, but it was blinking me errors 9 and 10 with a POST code 10000000. After a bit of googling I thought that it might be an RTC battery, so I did “motherboard state reset” procedure, and also tried taking out ssd and ram in various configurations. The only thing that changed is an error code - now it blinks 4,9,10 with 00000000 POST.
Just in case I ordered a fresh ML1220 cell (and a multimeter), but it appeared that my old one was just fine reading 3V. Swapped it anyway but it didn’t help.
Also I have a few type-c cables with a watt meter, and it seems like it doesn’t even tries to charge the main battery as the cable shows 1w max for a few seconds after pressing the power button.
Any help is appreciated, thanks.
P.S. tried with different cables, chargers, with/without ram, swapping ram slots/using single stick in different slots. Also, Fan is not spinning. Also nothing seems to be burned, no smell or other signs of overheating.
Removed board today to check the other side for any problems - seems good to me. Also tried starting bare motherboard with single ram stick - same result, just a few more red error codes for missing hardware.
Do we have an info on MB voltage test points somewhere?
Hi,
It sounds like a hardware failure to me.
Best to contact Framework support.
Yeah, but I have no warranty and they are probably overwhelmed with post-event requests now, maybe later when get home and have access to all my equipment as only have screwdriver, multimeter and tiny soldering iron with me :slight_smile: Also was a bit disappointed when discovered that there is no motherboard schematics available in open access, only for the repair shops who sign an NDA.
Anyway, I ordered myself an AMD 7840 motherboard, hopefully I’ll get it in time as I am traveling and will be at current location for only 2 weeks.
Finally got home. I first tried making a USB Close-Case-Debug cable (shoutout to @DHowett and the EC Card for the info), but unfortunately, it didn’t work for me—just got some random garbage output.
So I ended up connecting directly to the EC Debug UART port and finally got some readable output, though unfortunately, it wasn’t very useful:
--- UART initialized after reboot ---
[Image: RO, hx20_v0.0.1-369d3c3 2021-12-13 21:47:58 runner@fv-az209-518]
[Reset cause: reset-pin soft]
[0.000407 I2C Slave init ctrl:3]
[0.001914 KB boot key mask 0]
[0.001986 Inits done]
[0.023142 SW 0x05]
[0.023617 PB init-on]
[0.026945 kblight registered]
VIVALDI keybd disabled on board request[0.028018 Retry Charger init]
[0.028324 reconfigure kbbl complete.]
[0.028838 event set 0x0000000000800000]
[0.029366 KB init state: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --]
[0.031087 PB task 8 = init-on]
[0.034624 PB task [0.035586 PD1 Reset Complete]
8 = init-on, wait 98199]
Co[0.039377 Controller 0  App1 version B:3.4.0.2570]
[0.039860 Controller 0  App2 version B:3.4.0.2570]
nsole is enabled; ty[0.041965 Dead Battery Condition?]
[0.042385 cypd_update_power_status power_stat 0x0]
pe HELP for help.
> [[0.046225 cypd_set_power_state pwr state 3]
0.045612 hostcmd init 0x0000000000800000]
[0.068585 Updating [0.069721 cypd_set_power_state pwr state 3]
SOC Power Limits: PL2 28, PL4 70, Psys 52, Adapter 0]
[0.073362 CYPD 0 Ready!]
[0.074[0.075220 Controller 1  App1 version B:3.4.0.2570]
[0.075709 Controller 1  App2 version B:3.4.0.2570]
196 running with no b[0.078025 Dead Battery Condition?]
[0.078448 cypd_update_power_status power_stat 0x0]
attery and no AC]
[0.082396 cypd_set_power_state pwr state 3]
[0.093142 charge problem: static update, 0x0 -> 0x1 after 0.093120s]
[0.094626 Battery 0% (Display 0.0 %) / ??h:?? to empty]
[0.097015 charge problem: set voltage, 0x0 -> 0x1 after 0.096993s]
[0.100101 charge problem: set mode, 0x0 -> 0x1 after 0.100079s]
[0.105334 cypd_set_power_state pwr state 3]
[0.108822 CYPD 1 Ready!]
[0.129239 Retry Charger init]
[0.136661 PB task 8 = init-on]
[0.136954 PB task 8 = init-on, wait 99707]
[0.159230 running with no battery and no AC]
[0.205621 PD Source supply changed! old=0x0, new=0x02]
[0.215468 CYPD_RESPONSE_PORT_CONNECT 1]
[0.220888 Updating board_set_active_charge_port port 1]
[0.225129 CL: p1 s1 i3000 v5000]
[0.225549 TODO Implement pd_set_new_power_request port 1]
[0.230270 cypd_update_power_status power_stat 0x0]
[0.235419 INTR_REG CTRL:0 TODO Device 0x2]
[0.237369 PB task [0.237911 INTR_REG CTRL:1 TODO Device 0x2]
8 = init-on]
[0.239051 PB task 8 = init-on, wait 98319]
[0.263897 running with no battery and no AC]
[0.337841 PB task 8 = init-on]
[0.338309 PB task 8 = init-on, wait 99533]
[0.363955 running with no battery and no AC]
[0.399369 update charger!!]
[0.401467 Cancel shutdown]
[0.402143 AC on]
[0.415473 charge_request(15400mV, 0mA)]
[0.419491 power state 0 = G3, in 0x0020]
[0.438309 PB task 8 = init-on]
[0.438694 PB task 8 = init-on, wait 99616]
[0.450346 CYPD_RESPONSE_PD_CONTRACT_NEGOTIATION_COMPLETE 1]
[0.455990 Updating board_set_active_charge_port port 1]
[0.460329 CL: p1 s0 i3000 v20000]
[0.460775 TODO Implement pd_set_new_power_request port 1]
[0.465224 cypd_update_power_status power_stat 0x6]
[0.470997 INTR_REG CTRL:0 TODO Device 0x2]
[0.476485 INTR_REG CTRL:1 TODO Device 0x2]
[0.538906 PB task 8 = init-on]
[0.539316 PB task 8 = init-on, wait 99591]
[0.556130 Updating SOC Power Limits: PL2 40, PL4 45, Psys 57, Adapter 60]
[0.639666 PB task 8 = init-on]
[0.640192 PB task 8 = init-on, wait 99475]
[0.740297 PB task 8 = init-on]
[0.740694 PB task 9 = recovery, wait 199995]
[0.941466 PB task 9 = recovery]
[0.941875 PB task 0 = idle, wait -1]
[4.474227 BB PCH PWR down]
Got Mainboard Power Button event[8.997789 power button pressed]
[8.998219 PB pressed]
[8.998463 PB task 1 = pressed]
[8.998788 BTN wait RSMRST to asserted]
[8.999099 PB task 1 = pressed, wait 19365]
[8.999714 power state 5 = G3->S5, in 0x0020]
[9.000114 setup s5 power up!]
[9.019241 PB task 1 = pressed]
[9.020320 BTN wait RSMRST to asserted]
[9.020632 PB task 1 = pressed, wait 18610]
[9.039716 PB task 1 = pressed]
[9.040126 BTN wait RSMRST to asserted]
[9.040437 PB task 1 = pressed, wait 19280]
[9.047716 SW 0x07]
[9.060322 PB task 1 = pressed]
[9.060815 BTN wait RSMRST to asserted]
[9.061127 PB task 1 = pressed, wait 19196]
[9.071664 can't read any temp sensors!]
[9.072229 can't read any temp sensors!]
[9.080799 PB task 1 = pressed]
[9.081254 BTN wait RSMRST to asserted]
[9.081565 PB task 1 = pressed, wait 19235]
[9.101405 PB task 1 = pressed]
[9.101802 BTN wait RSMRST to asserted]
[9.102242 PB task 1 = pressed, wait 19164]
[9.121881 PB task 1 = pressed]
[9.122412 BTN wait RSMRST to asserted]
[9.122724 PB task 1 = pressed, wait 19157]
[9.142358 PB task 1 = pressed]
[9.142837 BTN wait RSMRST to asserted]
[9.143149 PB task 1 = pressed, wait 19209]
[9.162835 PB task 1 = pressed]
[9.163289 BTN wait RSMRST to asserted]
[9.163601 PB task 1 = pressed, wait 19234]
[9.183441 PB task 1 = pressed]
[9.203925 PB PCH pwrbtn=LOW]
[9.204289 PB task 10 = was-off, wait 479152]
[9.224426 Cancel shutdown]
[9.224823 PH G3S5->S5]
[9.225077 power state 1 = S5, in 0x0071]
[9.225580 PH S5]
Got Mainboard Power Button event[9.437960 power button released]
[9.438264 PB ignoring change]
[9.461233 SW 0x05]
[9.684071 PB task 10 = was-off]
[9.684468 PB released]
[9.684824 PB task 6 = released]
[9.685296 PB PCH pwrbtn=HIGH]
[9.685570 PB task 0 = idle, wait -1]
[10.072458 can't read any temp sensors!]
[10.072965 can't read any temp sensors!]
[10.225869 power state 5 = G3->S5, in 0x0071]
[10.226545 power state 1 = S5, in 0x0071]
[10.226933 PH S5]
[11.073028 can't read any temp sensors!]
[11.073656 can't read any temp sensors!]
[11.227233 power state 5 = G3->S5, in 0x0071]
[11.227875 power state 1 = S5, in 0x0071]
[11.228262 PH S5]
[12.073495 can't read any temp sensors!]
[12.074117 can't read any temp sensors!]
[12.228563 power state 5 = G3->S5, in 0x0071]
[12.229201 power state 1 = S5, in 0x0071]
[12.229588 PH S5]
[13.073960 can't read any temp sensors!]
[13.074577 can't read any temp sensors!]
[13.229888 power state 5 = G3->S5, in 0x0071]
[13.230519 power state 1 = S5, in 0x0071]
[13.230906 PH S5]
[14.074580 can't read any temp sensors!]
[14.075221 can't read any temp sensors!]
[14.231207 power state 5 = G3->S5, in 0x0071]
[14.231832 power state 1 = S5, in 0x0071]
[14.232219 PH S5]
[15.075038 can't read any temp sensors!]
[15.075645 can't read any temp sensors!]
[15.232519 power state 5 = G3->S5, in 0x0071]
[15.233138 power state 1 = S5, in 0x0071]
[15.233525 PH S5]
[16.075497 can't read any temp sensors!]
[16.076100 can't read any temp sensors!]
[16.233825 power state 5 = G3->S5, in 0x0071]
[16.234437 power state 1 = S5, in 0x0071]
[16.234825 PH S5]
[17.075956 can't read any temp sensors!]
[17.076552 can't read any temp sensors!]
[17.235253 power state 5 = G3->S5, in 0x0071]
[17.235860 power state 1 = S5, in 0x0071]
[17.236247 PH S5]
[18.076416 can't read any temp sensors!]
[18.077006 can't read any temp sensors!]
[18.236675 power state 5 = G3->S5, in 0x0071]
[18.237242 power state 1 = S5, in 0x0071]
[18.237757 PH S5]
[19.076875 can't read any temp sensors!]
[19.077459 can't read any temp sensors!]
[19.238022 timeout waiting for S5]
[19.238464 power state 10 = S5->G3, in 0x0071]
[19.239015 PH S5G3]
[19.240830 power state 0 = G3, in 0x0020]
[23.242284 BB PCH PWR down]
[24.078949 Boot issue: HW 0x00000612 BIOS: 0x0000]
I’ll keep digging.
That output from the EC Debug UART does actually help.
It is detecting the power button so that part is OK.
It is failing to read any temp sensors and because of that it is shutting itself off again because without temp sensors, it won’t know if it is getting too hot and damaging the laptop.
My guess is that there is an electrical short somewhere on the power supply to the parts that are involved in the temp sensing.
So, its probably a return to FW and get it fixed, or approach a repair shop and hope they can get the schematics in order to narrow it down and identify which capacitor or FET has most likely shorted.
Other ways to check are:
  1. Spray alcohol on the motherboard, try switching it on and see which part evaporates the quickest. That is most likely your shorted component.
  2. View the motherboard with an infrared camera and look for the hottest part in an unexpected place. That is the most likely shorted component.
That doesn’t seem to be the case—if I connect the main battery, the temp sensor error goes away. However, the rest of the output remains unchanged.
Yeah, I do have a thermal camera, but nothing appears to be getting abnormally hot.
So far, I think I’ve narrowed it down to the RT3613EEGQW-02 not having a high signal on the VRON pin. But it’s a bit tricky to investigate further without schematics or boardview files. I’m also limited on time at the moment—hopefully, I’ll have more availability to dig deeper next week.
Interesting. Do you get any flashing LEDs. The LED next to where you plug the charger in might flash after a while with some error code.
The EC does not really take part in producing the error code much.
BIOS send the EC a HC command to flash LED, EC just does what it is told to do. the EC does not detect the condition causing the flashing LED.
You can then look at this page to try to understand what the flashes mean:
Have you updated the BIOS firmware recently, sometimes this happens after a failed firmware update.
The output from the UART is interesting. Like @DHowett has said before it is fairly chatty.
Are some of the messages at the beginning because the power state can not be determined? It looks like it keeps talking about no battery and no AC though the messages talk about one of the ports being active. Presumably the battery has a charge on it still. I remember someone had a case quite a while ago about their charge state of their battery was really low and it was not until they had removed all power, pressed and held the power button drain residual current, then just put it back on USBC power and pressed and held the power button a few times to get it to reset the EC after doing a mainboard reset did it finally come alive again. It was as if it had locked itself in a certain state and needed a hard reset.
Alternatively you could try getting it to a mostly standalone state and seeing if it will boot while not connected to anything other than the power, keyboard, and DP or HDMI.
There is likely not a lot of documentation externally on the UART messages to help determine if one thing is triggering the POST not passing.
It would be interesting if there were some low level codes you could pass to the EC to get it to run some of the self-test routines and see what doesn’t come back as valid. That is likely way more involved than most people would dare venture.
Talking to low level components is very much a wild west of how things were put together from different engineering sources. Maybe keep an eye on the Marketplace for someone listing a mainboard cheap? It would be great to fix what you have, though at some point the replacement cost has to come into play with the time investment.
Thank you for the updates on what you have tried thusfar. It is always interesting to me and likely others, to see how people are troubleshooting along with the results along the way. We have been really spoiled that technology works so well for as intricate as all the components have become over the years.
Keep it up!
