120 hz panel?
Is there any plans for developing a 120 hz panel?
Have they said anywhere what the refresh rate of the panel is? I tried to find it listed anywhere and although I’ve found where the size, resolution, aspect ratio, and even panel brightness are listed everywhere, the refresh rate is rather absent.
Curious on this. I know they’ve stated that the panel is designed to be removed easily if damaged. Does this mean it can be swapped for one of a higher refresh rate? Or maybe one that is touch-enabled? I’m assuming their current panel is 60 hz since I can’t find it listed anywhere.
It is indeed 60hz, check this thread for all the panel specs they have mentioned so far: Looking for a specsheet on the screen before ordering - #2 by nrp
