Autodesk Fusion issues
Anyone use Autodesk Fusion on their framework 16 with the discrete graphics module? I’m having a horrible time getting it to work. The software doesn’t freeze but the window graphics do. Stuck with the Autodesk Fusion splash screen and no way to see or load any models etc.
I just did an install of the most recent drivers update and still have issues. Set it to use the discrete graphics in Windows graphics settings and tried all different types of settings changes in the AMD app.
Anyone having the same problem? Computer works fine playing games and such.
When working with workstation programs (CAD, CAM, editing, creation, etc) be sure to stick with the approved display drivers from Framework. They are the ones that have been tested most extensively to work with the Framework hardware.
Side note: I have a workstation at work using a RX 6750XT card that does CAM and CAD and the latest AMD drivers crash all the time. Finally had to go back to their “PRO” (aka workstation) drivers from 2022 to finally get it to be stable.
I’m currently using the provided drivers from Framework. No issues on anything but fusion. Just stuck with the splash screen. Can’t do anything.
I don’t have a 16, but I wonder if you forced Fusion to use the built-in graphics if that might work? Do the two GPUs use the same graphics driver?
So I have two additional monitors set up and for whatever reason it works just fine on the external monitors but not on the built in screen. I’m going to try and disconnect the screens and see if it works after I finish my design.
