Hi guys,
During my disassembly of the Framework laptop, I noticed that the intake vents are shorter than the diameter of the fan.
Maybe for the future bottom case revision, maybe we can enlarge the vents, a rough measurement is an added 1cm longer.
Not sure if it will help airflow by allowing more air to be drawn in and exhausted at a quicker rate.
