Daisy Chain Expansion cards?
This isn’t necessarily a feature request, just asking out of curiousity.
I noticed the interior part of the expansion cards looks like USB-C. So I was wondering if it was possible to plug an expansion card into another expansion card? i.e. Having a USB-C expansion card installed in the laptop, and having an SD card expansion card plugged into the USB-C card.
I recognize this is probably not an intended use-case, but something I just thought of.
Additionally, because the interior connectors look like USB-C, are we able to directly use the interior ports for things like USB-C dongles/drives instead of expansion cards?
Yes, you can plug other cards into the USB-C Expansion Card, and can plug directly into the USB-C port that the Expansion Cards plug into, assuming the plug you have is thin enough to fit.
