Every so often I get this error message, randomly, while the laptop is sitting docked. Rebooting fixes the issue. It’s basically crashing. I do not have a DIY edition and I have been using this laptop for a while now without issue.
Framework 12th Gen (not DIY)
12th Gen Intel(R) Core™ i5-1240P 1.70 GHz
Windows 11
I am not really sure what else of relevance there is to share to please help me help myself in terms of providing additional information to debug the issue. I have lost work a few times now as a result of this.
Sounds like your drive is accidentally coming unplugged. Is there ever any movement or tapping on the case when it happens? I suspect that the drive wasn’t installed properly from the factory.
Interesting take, I didn’t consider that. I’ve had it open before and haven’t noticed any such issue but will take another look. I don’t believe there is a correlation to movement, it sits docked 90% of the tim, but now that you’ve brought this up I’ll keep it in mind! Thanks for the tip!
