As you can see on the picture I have a display error which is clearly visabel on white background. I have contacted the support but they didn’t answer me. (I have recieved the conformation email that they are working on it and I have to wait) So now I want to know is the screen unrepairable and do I need to buy a new one or is there a fix to that. I don’t know how this error appeared in the first place because I own this laptop since routhly one week and on the first start it wasn’t visable. On the next day I started my laptop and saw it.
Well, of course, wait for support to respond. You are still under warranty so you shouldn’t have to buy anything. One thing you could try is finding the user guide to replacing your display, so that you can see how you can check your display cable and make sure it is firmly inserted. Be careful, the display cable is complex and fragile. That would be my first guess. Otherwise, it could just be something bad with the panel.
I have already tried to unplug it and plug it back in. Sadly it didn’t help but thanks for your reply
