Fedora 40 on Framework 16
fingerprint reader was working fine. Now it does not prompt anymore at login/sudo. Also disappeared from gnome Users settings.
I could see this error from the service:
▶ journalctl -b 0|grep fingerprint
Jul 18 18:32:52 gearo gdm-fingerprint][2666]: pam_unix(gdm-fingerprint:session): session opened for user fryorcraken(uid=1000) by fryorcraken(uid=0)
Jul 24 14:15:55 gearo gdm-fingerprint][79169]: pam_fprintd(gdm-fingerprint:auth): ReleaseDevice failed: Release failed with error: The device is still busy with another operation, please try again later.
I restarted the laptop, did not help.
I did a “reset to default and enable TPM” to see if it could help. No help either.
Apart from standard upgrades, the only think that may have impacted is that I loaded a custom signed module for the led matrix. I don’t know if it stopped working since then or because of something else.
Now, journalctl does not seem to print any errors about it anymore.
I was really enjoying it so your help is very much appreciated!
It does not even seem to show when running lsusb:
▶ lsusb
Bus 003 Device 002: ID 05e3:0610 Genesys Logic, Inc. Hub
Bus 003 Device 003: ID 05e3:0610 Genesys Logic, Inc. Hub
Bus 003 Device 004: ID 05e3:0610 Genesys Logic, Inc. Hub
Bus 003 Device 005: ID 32ac:0020 Framework Computer Inc LED Matrix Input Module
Bus 003 Device 006: ID 0e8d:e616 MediaTek Inc. Wireless_Device
Bus 003 Device 011: ID 32ac:0020 Framework Computer Inc LED Matrix Input Module
Bus 003 Device 012: ID 32ac:0012 Framework Laptop 16 Keyboard Module - ANSI
Bus 004 Device 002: ID 05e3:0625 Genesys Logic, Inc. USB3.2 Hub
Bus 005 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 006 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 007 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 008 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 009 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 010 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
I followed instructions in Fingerprint reader doesn't show up in settings - #2 by Jared_C_Strong
- Shutdown PC
- Wait a bit
- Start again
fingerprint read is back and configured as before.
Not sure if/how to report that to framework.
