Fix for my freezing Framework 13 12th gen
I’ve seen a lot of posts here about people having trouble with their laptop freezing (1, 2) and most seem to need a motherboard replacement to solve so I thought I’d give my story which was thankfully a bit less costly to fix.
I tried pulling both batteries (main battery + CMOS battery), let that sit for a few minutes but it didn’t solve the problem. Then I tried reseating the RAM and that didn’t work. Then I decided to take it apart and put it under a microscope, both figuratively and literally. Sadly I found that the build quality is substantially sub-par, but I was able to solve my issue.
First I found that there seems to be flux residue around the pins on the RAM connectors. I don’t have a good picture of this as it was through the microscope and I didn’t have a good setup for it. Seems that the flux wasn’t properly cleaned off the board.
Second I found that one of the WiFi coax cables was routed under the RAM and got pinched. I don’t think this was actually the problem, but this does seem like a design defect to not have this properly separated from an area that’s going to get pinched. I put some Kapton tape around this, though I really should go back with heat shrink tubing since the radius is so small.
[Can’t include picture of this because I’m a new user]
Then I found upon taking the thermal management part (fan, heat block, heat pipes, heat sink) out that a full 30% of the top of the CPU die wasn’t properly thermal pasted.
Finally, what I think is the culprit. This is a picture of the bottom side of the thermal block. This is after I’ve put some Kapton tape over the spot, but you can see where either some of the copper has rubbed off, or some material (which I think would be solder) has rubbed on. As shown, I added some Kapton tape on that area and around it and reinstalled it. I suspect this is the problem because, in hindsight, I do remember most if not all of the crashes before it stopped booting seemed to correlate with my use of the keyboard (something I wish I’d have thought of sooner).
If you’re mechanically competent and have been having any issues with your Framework laptop I’d suggest you disassemble it and check the thermal management part. If it looks like this, put a good quality (won’t tear) insulator between it and the motherboard.
In my case, my laptop went from wouldn’t even get to the Framework logo to boots and doesn’t freeze at all with these changes. Overall I’m rather disappointed with Framework’s quality, but thankful that at least nothing seems to have been burnt up.
hi, where in your photo you think is the area of the CPU with improper pasting?
The top third where you can see the dark surface of the CPU.
I would assume that in this area the paste now sticks to the aluminium cooler. how else should the paste have been squeezed out all around the CPU and still leaving a hole in that area?
If there were air bubbles in/below the thermal paste, the air would still push superfluous thermal paste out.
If the thermal paste is properly applied and not dried out you’ll generally have a relatively even residue on both the CPU and the copper heat spreader, like it’s on the bottom 2/3.
It could also have pumped out over time but looking at the squeezed out bit the top never had all that much to begin with.
Give that puppy some ptm and it’ll be better than new for a long time XD
where would the air bubbles stem from? application in industrial style hopefully is shaping a bubble free blot. when placing the cooler, entrapped air should evade very efficiently and completely as its viscosity is dramatically lower than the one of the paste.
