Framework 13 AMD USB-C Port Issues
Description of the Issue
I’ve encountered a problem with the Framework 13 AMD laptop, specifically involving the USB-C port. When connecting an iPhone 16 Plus to the port, the connection is unstable—the phone repeatedly connects and disconnects. This behavior makes it impossible to maintain a reliable data or charging connection.
Steps to Reproduce
  1. Use a Framework 13 AMD laptop.
  2. Connect an iPhone 16 Plus to the USB-C port using a genuine Apple USB-C to Lightning cable.
  3. Observe the connection behavior.
Expected Behavior
The iPhone should remain consistently connected, allowing for uninterrupted charging and data transfer.
Actual Behavior
The connection drops and reconnects repeatedly. This behavior persists regardless of which USB-C port is used on the laptop.
Troubleshooting Attempts
  • Verified the cable works by testing it with another device (no issues observed).
  • Tried different USB-C ports on the Framework 13.
  • Updated to the latest BIOS and drivers available for the Framework 13 AMD.
  • Tested with another iPhone 16 Pro, which exhibited the same behavior.
  • Tested an iPhone 12 Pro and an iPad Pro, which worked without any issues.
  • Tested on both Windows and Linux with the same results.
System Details
  • Laptop Model: Framework 13 AMD
  • BIOS Version: [Insert BIOS version]
  • Processors: 16 × AMD Ryzen 7 7840U w/ Radeon 780M Graphics
  • Memory: 30.6 GiB of RAM
  • Graphics Processor: AMD Radeon 780M
  • Manufacturer: Framework
  • Product Name: Laptop 13 (AMD Ryzen 7040Series)
  • System Version: A7
  • Phone Model: iPhone 16 Plus
  • Cable Used: Genuine Apple USB-C to Lightning
Additional Observations
  • The issue seems to occur only with the iPhone 16 series. Other Apple devices (e.g., iPhone 12 Pro, iPad Pro) and non-Apple USB-C devices connect without problems.
  • The problem persists whether the phone is locked or unlocked.
  • Relevant dmesg output from Linux:
    [ 2518.753739] usb 7-1: new high-speed USB device number 12 using xhci_hcd
    [ 2518.888407] usb 7-1: New USB device found, idVendor=05ac, idProduct=12a8, bcdDevice=17.04
    [ 2518.888415] usb 7-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
    [ 2518.888418] usb 7-1: Product: iPhone
    [ 2518.888420] usb 7-1: Manufacturer: Apple Inc.
    [ 2518.888422] usb 7-1: SerialNumber: ...
    [ 2519.267027] apple-mfi-fastcharge 7-1: USB disconnect, device number 12
    [ 2519.498157] usb usb1-port1: Cannot enable. Maybe the USB cable is bad?
    [ 2521.217927] usb usb1-port1: Cannot enable. Maybe the USB cable is bad?
    [ 2521.218022] usb usb1-port1: attempt power cycle
    [ 2522.849953] usb usb1-port1: Cannot enable. Maybe the USB cable is bad?
    [ 2523.737949] usb usb1-port1: Cannot enable. Maybe the USB cable is bad?
    [ 2523.738069] usb usb1-port1: unable to enumerate USB device
    [ 2524.785890] xhci_hcd 0000:c1:00.3: Refused to change power state from D0 to D3hot
    [ 2526.153738] usb usb1-port1: Cannot enable. Maybe the USB cable is bad?
    [ 2527.874281] usb usb1-port1: Cannot enable. Maybe the USB cable is bad?
    [ 2527.874373] usb usb1-port1: attempt power cycle
Request for Assistance
I’m looking for guidance on whether this issue is hardware-related or a driver/firmware compatibility problem. Any troubleshooting tips or updates that might resolve this would be greatly appreciated.
Thank you for your attention to this matter. Please let me know if further details or logs are needed.
It is a bios issue and happens with the USB-C iphones (so 15 and 16 series)
can they fix this with a bios update
Has Framework identified a cause? Or anyone else conclusive proven root cause for that matter. Last I read, it’s only been guesses from forum members. Could be on the Framework side, the apple side, or perhaps most likely, some on both sides.
Don’t know about the reason, haven’t seen any official statements. Only that atleast the 3.06 BETA bios mentioned it in the known issues part.
I guess the best guesses right now are somehow related to USB-PD negotiations.
I also have a similar issue with a Framework 16" and Phone Internet sharing. When I use the USB-C to USB-C cable from an iPhone 15 to Laptop I get a beep every 3 seconds, what is going on. USB-C phone tethering is odd to say the least on these laptops, my last system I just plugged in the cable and selected “Connect via BT or USB”, it took me a while to figure out I had to enable the “Personal Area Network” on this Laptop to get USB tethering to work and I think my wi-fi(iphone to laptop) connection is faster than the USB-C teathering which is the opposite of previous systems. Why is USB-C to USB-C an issue.
A possibly related data point: the past couple days, I saw strange behavior while gaming on my FW13 AMD (–> high power draw) where the computer itself would rapidly alternate between battery and AC power while plugged into the wall. This occurred on both of the rear two motherboard ports; I didn’t try the front two. On a hunch, I swapped the USB-C cable – just the 3rd-party cable, not the power brick – and the issue immediately resolved.
@Arno_Joosen Since you mentioned you tested the cable with another device, but not a different cable with the same device, maybe there’s an issue between certain types of cable and the FW13?
I have already tried different USB-C cables with my iPhone, but the issue persisted.
This has happened to me as well with an iPhone 15, same model of laptop. It might just be iPhones with USB-C ports. I tried multiple cables and ports, it happened with all of them.
I am unable to charge my iPhone 16 pro with my new framework laptop! Unbelievable. It’s 2025! This has been going on for over a year looking at issues posted in reddit. Is it unreasonable to ask for this to be fixed ASAP?
Please fix this.
