Framework 13 DIY (Ryzen 7) double types letters
Hey folks, I’ve noticed that my laptop will often “double type” letters (at least once every hour during a heavy coding session, often enough to really notice). It’s been happening pretty consistently since I got the machine, and I haven’t seen much discussion online about it. Wondering if anyone else has this problem?
  • Arch Linux
Which release version?
  • September
Which kernel are you using?
  • 6.10.8
  • 0.0.3.5
Which Framework Laptop 13 model are you using? (AMD Ryzen™ 7040 Series, Intel® Core™ Ultra Series 1, 13th Gen Intel® Core™ , 12th Gen Intel® Core™, 11th Gen Intel® Core™)
  • AMD Ryzen™ 7040 Series
I have not yet experienced this on my Framework 13 AMD. I’m on PopOS 22.04. Mind you I haven’t been doing heavy typing or coding across an hour span.
Have you only seen it in your IDE or have you seen it also in a terminal or another application?
I experienced the same problem with the same laptop model, with fedora 40 kionite :slight_smile:
In my case it happens more often on the left side of the keyboard, with for example c r e x, I am glad to see that I am not the only one :slight_smile:
Oddly enough, I’ve been seeing this issue more frequently since I re-installed Arch on my computer the other week. It’s happening once a day or so now. I wonder if getting a new keyboard would fix it?
