Framework 16 restarting at random times with no warning
Hello!
So today I got my Framework and I couldn’t be happier! The only issue I found is at times, with no warning my PC just goes black and restarts…no warning or anything just turns off… I’m not sure what could be causing this.
It’s important to note that I have an EGPU connected running an Nvidia Geforece RTX 2070 Super…I’ve mangaed to connect them and they’ve been working well, but I’m not sure if that is a factor or not.
The times it crashed were not when I was gaming or anything, but really when I was just idel watching a video or just not looking at my computer…it’s almost as if it fell asleep and just restarted…
Any help is much appreciated…Thank you!
Does it really reboot or does it only go into standby (like if you closed the screen lid)? If it’s only going into standby, you might just have triggered the lid sensor by putting something magnetic (including other laptops or certain rings) next to or below the laptop.
Do you know the location of the magnetic sensors? I try to do this. Keep the lid open but put a magnet at the sensor but it doesn’t work.
I’ll see the magnet thing but I’m positive it fully restarts…it shows the framework logo when it does it and my computer goes to the Lock Screen with most applications closed off
So I posted a post a month ago when I first got my laptop that it would sometimes restart with no warning…and it just happened again… wondering if there is way where I can check why it happened in the first place?
And I actually check event viewer and my eror says the following “The system has rebooted without cleanly shutting down first. This error could be caused if the system stopped responding, crashed, or lost power unexpectedly.”
I would suggest using the computer without the eGPU connected, but considering it has been a few weeks since the issue last occurred, you may be waiting a while.
Mine didn’t restart, but completely shut down. It only happened twice since I got mine from batch 6. Once when I was in game playing, the game started to go rather slow and sluggish, but the mouse was moving just fine then boom powered off. Then a few months later when I powered it on, it powered its self off again.
I do leave it plugged in 24/7, and shut down every night. Windows 11, AMD DIY edition, it doesn’t get too hot and is well ventilated, its connected to 1 external 32’ monitor via HDMI with laptop display opened… I’m wondering what this problem is and how to fix it?
Is the FW16 updated machine to the newest BIOS? I got mine in Batch 6 as well; though I mostly have used it lightly and not as a daily driver. I surmise there are some little issues in the BIOS maybe related to the EC that is causing the panic shutdown/restart.
Yeap its updated to version the 3.03 version and I also updated the drivers from the Driver Bundle 2024-04-02.
I can do without that Adreniln bloatware though, I just wanted the graphics driver not the rest of that crap.
Good to hear you are up to date with the BIOS and the latest drivers.
I had to hunt around on AMD’s website for the “Workstation” drivers for my machine at work that doesn’t come with the excess bloatware of the Adrenaline system. They are much harder to find on their website unfortunately. I have an old version from a year or so ago that I downloaded when I built the system at work and they have been solid.
Had to reload the drivers thanks to Windows corrupting itself and luckily I had squirrelled away that download for safe keeping. I tried looking and gave up after about 10 minutes then remembered I had saved it with all the drivers for the ASUS motherboard when I built the machine a year ago.
If it happens again, you might log a ticket with support. If they see enough of this happening it will get a little more scrutiny from the development team ideally. :white_check_mark:
Has a solution been found for this? Mine does it too.
Yeah same here, Checked the event viewer and got exact same message. Happening quite often actually
Critical 2025-11-06 6:17:06 PM Kernel-Power 41 (63)
Critical 2025-11-06 11:31:12 AM Kernel-Power 41 (63)
Critical 2025-10-27 7:38:49 AM Kernel-Power 41 (63)
Critical 2025-10-24 12:29:18 PM Kernel-Power 41 (63)
Critical 2025-10-20 10:37:44 AM Kernel-Power 41 (63)
Critical 2025-10-14 8:34:13 PM Kernel-Power 41 (63)
Critical 2025-10-14 6:40:04 PM Kernel-Power 41 (63)
Critical 2025-10-08 8:03:56 PM Kernel-Power 41 (63)
Critical 2025-09-28 6:35:04 PM Kernel-Power 41 (63)
Critical 2025-09-28 7:07:18 AM Kernel-Power 41 (63)
Critical 2025-09-26 9:07:32 AM Kernel-Power 41 (63)
Critical 2025-09-24 1:44:09 PM Kernel-Power 41 (63)
Critical 2025-09-24 7:54:20 AM Kernel-Power 41 (63)
Critical 2025-09-23 6:18:39 AM Kernel-Power 41 (63)
Critical 2025-09-22 7:56:08 AM Kernel-Power 41 (63)
Critical 2025-09-19 11:08:27 PM Kernel-Power 41 (63)
Critical 2025-09-19 4:07:58 PM Kernel-Power 41 (63)
Critical 2025-09-19 4:00:58 PM Kernel-Power 41 (63)
Critical 2025-09-19 2:31:15 PM Kernel-Power 41 (63)
Critical 2025-09-19 1:52:12 PM Kernel-Power 41 (63)
I have a similar issue with mine, for reference:
I run Windows 11, I’ve had the issue with both the AMD graphics module installed and without it while using the igpu.
This has been happening with the bios that was installed on the machine when I purchased it in January of 2025, as well as the current most up to date BIOS.
I use the laptop with the standard 180W charger that it comes with from FW.
I have seemingly found a pattern for how this happens:
  1. The computer is in sleep mode and has not been used for some amount of hours.
  2. I open the laptop and log in. The instant I start doing anything seemingly the spikes power use (eg. open a Steam game, start using a web browser), the machine’s screen will go completely black all of a sudden as if it was a desktop and its power cord was just ripped out.
  3. The only thing that will get the machine back on is the power button, after which it boots as if it was always off.
Critical 2026-03-21 10:57:12 AM Kernel-Power 41 (63)
Critical 2026-03-20 12:38:26 AM Kernel-Power 41 (63)
Critical 2026-03-17 7:58:00 PM Kernel-Power 41 (63)
Critical 2026-02-16 10:12:38 PM Kernel-Power 41 (63)
Critical 2026-02-13 2:47:00 PM Kernel-Power 41 (63)
Critical 2026-02-11 3:20:37 PM Kernel-Power 41 (63)
Critical 2026-01-16 5:02:47 PM Kernel-Power 41 (63)
Critical 2026-01-16 4:04:17 PM Kernel-Power 41 (63)
Critical 2026-01-11 1:29:30 AM Kernel-Power 41 (63)
Critical 2026-01-07 9:38:13 PM Kernel-Power 41 (63)
Critical 2026-01-04 8:19:18 PM Kernel-Power 41 (63)
Critical 2026-01-03 9:18:51 PM Kernel-Power 41 (63)
Critical 2026-01-01 3:03:10 PM Kernel-Power 41 (63)
Critical 2025-12-31 11:30:20 PM Kernel-Power 41 (63)
Critical 2025-12-26 11:00:53 AM Kernel-Power 41 (63)
Critical 2025-12-24 10:44:06 PM Kernel-Power 41 (63)
Critical 2025-12-24 7:43:44 PM Kernel-Power 41 (63)
Critical 2025-12-12 8:46:08 PM Kernel-Power 41 (63)
Critical 2025-12-10 11:14:36 AM Kernel-Power 41 (63)
Critical 2025-11-30 2:15:32 PM Kernel-Power 41 (63)
Critical 2025-11-09 2:06:54 PM Kernel-Power 41 (63)
Critical 2025-10-15 10:38:20 PM Kernel-Power 41 (63)
No solution on this old thread? This is occurring on my fully updated 16, with Windows 11, as of April 2026
Which FW16 do you have?
Also what ram make/model and ssd make/model/firmware version
Batch 14 Ryzen 9 7940, running it with the graphics module, Radeon RX 7700S
Kingston FURY Impact 64GB (2 x 32GB) DDR5 5600
OS: WD SN740 M.2 2230 SSD 2TB
Aux storage: WD Black SN850x SSD 4TB
The problems may be caused by old firmware on the SSDs.
Backup your important files and then upgrade the firmware on both SSDs to the latest.
There is a firmware update tool for windows on the western digital web site.
I’m hesitant, as my daughters Framework 13, 13th gen MB, just burned up her WD Black, that I’m replacing. First time I’ve had an SSD completely go unreadable.
That is actually quite a common failure mode for the SSD. Completely unreadable.
The NVME SSD is just a bunch of chips. Any one of them can fail, and it is quite often the controller chip that fails before the flash chips fail.
If you have everything backed up, it should not be a problem, even if it does fail.
Most WD SSDs have a 5 year warranty, so if they do fail, you will get a replacement for free, if it is less than 5 years old.
It is probably worth running the WD firmware update tool, just to see if it tells you something can be upgraded or not. Without actually changing anything.
If you are interested in the reason for the restarts caused by the SSD firmware. On some old firmware versions, it created AER errors on the PCIe interface. After too many AER errors, the laptop will reboot.
The new firmware fixes it so there are no AER errors, thus no reboots.
