The Framework 16 obviously has some crazy potential and I hope to see a refined iteration with some upgrades (and new colours! )
I have one suggestion that would really enhance the experience for those having that configurable portable desktop experience with an uncompromising creative ambition. If someone can tell me if this would be feasible or realistic in the near future would be much appreciated!
Utilising the bottom keyboard deck as a secondary screen in the shape of a pogo pin module with touch/pen support, artists would appreciate a dual screen setup, and a drawing surface a little more practical than traditional 2 in 1s. Maintaining the traditional clamshell form factor for the graphics module.
The Framework 12 i think offers incredible utility for students but I think when targeting hard-core creatives that crave a personalised device that maintains dedicated graphics power as an option would change the game for many users like myself!
These are just simple mock-ups I made in canva for future Framework 16 iterations.
I’m afraid a screen such as that is not possible, at least without a major redesign. There isn’t the vertical room / z-height. There are mounting rails and the pogo pins which take up room. And there is also a problem of data bandwidth, for a high resolution, high refresh rate screen. The input deck only has usb 2.0.
I would think, and hope, FW did consider creating a design which could accommodate a full screen like that. I’d assume that they couldn’t make it work within the design constraints they had. The FWL16 was already a really ambitious design, with risk attached.
Perhaps we’ll get something like this in a future laptop, or in a whole refresh of the FWL16 somewhere down the line.
Someone has actually done a Mad Max prototype of this:
E-paper is the most viable route due to both space and power limitations¹, but for your project you’d have to find a display that’s large enough, which is a challenge in and of itself.
¹You have approximately 2.5mm of clearance in there and the pogo pins provide USB 2.0, so 480Mbps and 500mA@5V - 2.5W.
I think Lenovo or someone else came out with a dual screen setup where the keyboard area was another screen. It did not take off well or at all. Extremely niche and costly.
However, there is nothing stopping someone from making (or commissioning someone) to make a custom 3D printed chassis that is substantially thicker to accommodate a screen where the input deck is. It would weigh a bunch and probably be much more fragile than it is worth though.
