Framework 16 - Stuck Screws (Help!)
Hello!
I was recently working on my laptop (the hardware, at least), to get some hair out of a GPU fan. While putting it back together, I overtightened both one of the interposer screws, and one of the other locking screws.
These are both captive screws, and I am wondering if there’s any way to get them out. Trying to remove them with the driver just results in endless spinning and clicking sounds. They’ve both wallowed out a bit, although the screwdriver still fits.
I’ve got some replacement screws I purchased arriving sometime next week, and while the GPU itself does still work (for now, although with some graphical glitches appearing now and again), I am hoping there’s some ways to get these screws out, as I’ll need to replace the interposer.
I’ve tried the rubber band method, and simple adhesives. Neither work, so I’m mulling using J-B Weld. I’m just going to consider this an expensive lesson, and any advice is appreciated. I’m OK breaking the interposer, but I’d like to save my mainboard and GPU.
Thank you,
Deiniol
TL;DR:
I overtightened two captive screws, and need to remove them entirely. Requesting advice before acting. I am OK with losing the interposer and replacing some screws.
The piece that holes in captive screws is usually just a plastic lock spacer on the opposite side. If you have the pieces out, you can use a tweezer or something to pull that off, then remove the screw.
If the screws are stuck in place and you can’t get a screwdriver to bite (stripped the heads?) you can also try verrry carefully dremeling a flathead slot to them out with a flathead piece instead of the standard star or philips.
I would only advise that if you’re really stuck. Carefully clean any debris/metal filings left after so they don’t spread around the board
If nothing works at the end, a very small drill bit straight down the screw will remove it, but can obviously damage things if you’re not careful
Unfortunately they are stuck to the laptop currently.
I did make an attempt with the dremel earlier and it failed. I’m a little worried about using a drill. I still want to try the J B Weld method.
I’m also wondering if it’d be possible to insert new screws after removing them.
Update on this, ended up sending it to framework to be fixed. A bit costly, but it works now at least.
