Hi all,
I want to buy a Framework 13 Factory Seconds, but I’m a little irritated from the store pages.
I found the “Factory Seconds Framework Laptop 13 DIY Edition (11th Gen Intel® Core™)” which according to the listing should include a pre installed WiFi Card according to the listing.
And then I found the “Factory Seconds Framework Laptop 13 DIY Edition (11th Gen Intel® Core™) Kit”, which also writes that a WiFi card is included, but when you go through the configure it, it has bring your own selected.
I tried to add links here, but it seems to be unable for me from my mobile
Both have the same price and B Stock. For the kit the listing and the configurator seem contradict themself.
Does anybody know whether a card is included or pre installed?
Thanks for your help.
BR Christoph
