Framework Fragile Screen?
Hello Everyone,
I have noticed an issue with the framework 13’s screen fragility, and wanted to know if it’s a common issue with anyone else.
Context:
I purchased a framework 13 a few months back, and I’ve been overall very happy with the laptop. Great performance, and I’m to find a manufacturer that seems to want to help its customers.
The only hiccup I encountered was my screen going partially black after less than one month. No rough handling, just regular student use. I assumed it was a defect, contacted support, answered questions/sent photos, and they sent me a replacement. It was an easy repair, and I was overall very happy I went with framework for this specific reason.
Unfortunately, just two months later, the screen has the same issue. This is out of nowhere, no rough handling, just opening it up and the screen is black. I know lcd screens are not the most durable, but this hasn’t happened to me on any other laptops. I know I could easily replace it, but how can I know it won’t fail again?
Issue:
The screen appears to break easily, and it’s not a one time thing. I’ve reached out to framework support, so I’m not looking for fixes here. What I am wondering is if anyone else is seeming to have this issue. I know I’m just one case, but for me, this has impacted my work. I’ve treated it like any other laptop I’ve used previously, but it’s the only one to give me such spontaneous failures. Has anyone else had this issue? It seems like a huge flaw in an otherwise great product.
Some of us have been downright abusive and not run into this issue. My laptop has been dropped (while closed) and it’s fine…other than the dbrand skin being a bit scuffed now.
I’ve seen issues where other users complained about it too, especially LCD backlight failure, but it doesn’t seem to be as common as Rx 7700S just plain dying on FW 16s. That’s a plague right now.
This just happened to my FW13. It’s about a year old and I’ve treated it well. Will replace the screen and move on, hoping it won’t happen again.
That is a bummer to see @Longomontanus. It really is amazing that the advanced screens of today do not fail more often. Sometimes it is a random fluke even if you did everything right.
It is always a good idea to raise and lower the screen from the top center to minimize the twist on the screen.
They did release a newer screen with a little better resolution, though I think you will need to buy a different bezel because it has rounded corners. So you could upgrade the resolution on the new screen. Bummer it happened, though the silver lining is you can repair it yourself and it is not outrageously expensive.
It doesn’t matter which screen do you use (original or 2.8K) - there is only one type of bezel that fits both. Yes, 2.8K screen has rounded corners but it’s not due to bezel itself :slight_smile:
Thanks guys, good info! @pkunk it’s true, one of the main reasons for buying this laptop was the fact that it’s easy and reasonable to replace things that break, so nothing to complain about there. Maybe I’ll take the opportunity to get the higher resolution screen. Have a great weekend.
Just changed to the higher resolution screen (https://frame.work/products/display-kit?v=FRANJF0001) and very happy with the result. Changing the screen was easy following the guide. I haven’t noticed any issues with the rounded corners. Running Windows at 150% magnification as 100% is TINY. Now to be extra careful with it and hope it lasts.
Congrats on the new screen upgrade/replacement @Longomontanus! Glad it went smooth for you.
