FW13 Pro Batch 1 Guild
Just got an email:
As we were preparing Framework Laptop 13 Pro for mass production ramp, we discovered two issues, one on the new haptic touchpad and another on the custom display. We’ve since root caused and found solutions for both of these. However, to bring in these updates, we need to delay the start of mass production, which pushes first batch shipments about one month from late June into late July, with some risk of some units in early August
Unfortunate, but I’d rather have a fixed laptop than multiple support cycles after receiving it
Me too :frowning:
Edited to say: Whilst this is obviously disappointing, I agree with @Naxels … better to find out in advance with a delay, than have to jump through hoops later to get things fixed.
Too bad for the first batches (I am batch 14 and will likely not be hit by this impact), but I like the transparency Framework gives us about the issues. And I like they will not ship products with known issues (saying as owner of a FW12 with a cracked -and changed- case)
I’m devastated.
Slightly surprised at how last minute it feels the call was to announce the delay. It also paints a picture of how short the delay is from manufacturing to shipping on batch 1. I work at an SI and our odm production run is more than a month from prep to shipping to us, and this is a product they sell to others too.
I got that email too.
I’m batch 8 though, so I’m wondering, if and how that affects me. They say their goal is to catch up with planned August deliveries. Kinda doubt they’ll make it, if they say there is a risk that some batch 1 could be pushed to August.
I had cancelled my batch 1 order,
Because of the delay? Or something else?
right no, it dosent make sense to buy ram and ssd , and also waiting for nvidia rtx spark
Yeah, the 32Gb RAM in my current FW13 cost me £55… the 32Gb for the new Pro is over £400 … which is just insane. Fortunately I’ve an SSD to carry over.
The spark is going to be interesting, but if you think that it’s going to be cheaper, I fear you will be disappointed. Not sure how well they’ll do with OS support either.
Batch 1 mainboard order here, my order has shipped and it’s from a warehouse within US. Should be receiving it on Thursday.
Are you testing it out now?
I got my batch 1 mainboard today. It seems to mostly work. I can’t get the computer to recognize the battery percentage though. It still works on battery, but it thinks that a battery is not connected? I’ve tried resetting the mainboard and also reconnecting the battery several times, but nothing changed :thinking:. The pins to the battery connector don’t look bent. I am using the original 55 Wh battery.
Edit:
Ran Geekbench 6.7.1 under Fedora 44 in balanced mode on battery. 2436 single core, 9610 multicore. https://browser.geekbench.com/v6/cpu/18485773
2871 single core, 12561 multicore in performance mode. https://browser.geekbench.com/v6/cpu/18485806
I can’t even tell if the fan is running or not. Definitely a lot quieter than the intel 1240p I had before!
Edit again:
The fan is spinning! It’s just super quiet.
Mostly done, I put it in a reddit thread
I haven’t look into the bios yet but in Ubuntu everything mostly work after I upgrade the kernel & disable secure boot. I too noticed the fan is very quiet.
Plugged the battery back into the 1240p mainboard, and the battery percentage does pop up. Which is a bit concerning to me that this might be a “defective” board. It really isn’t a huge deal though, as I keep it plugged into a dock 95% of the time anyway, and it still gets power from the battery. Everything else about the board works great. I’ll just have to keep in mind I won’t know exactly when it will die on battery. :sweat_smile:
Think with some tuning, maybe you can beat the FL13 AI HX 370 scores?
https://browser.geekbench.com/v6/cpu/search?q=framework%20laptop%2013&sort=multicore_score
Score distribution of other HX 370 and 358H (non-framework) laptops:
Not sure what else to do - I’m already on 7.1.1 kernel and still cannot top 15K MT.
TBH I think that AMD having better CPU efficiency under load is to be expected. Especially with the lack of SMT on the X7.
Also the max CPU package power I can get the X7 to run is at 31-32W under performance power mode and I think the 370 board can burst higher than that.
Odd that you’re not ‘seeing’ it burst beyond 32W. Other 358H on the market have been configured to burst to 60W+. Maybe it’s a kernel / Linux thing? Did you give Windows 11 a go just to test out if it’s OS related / specific?
Lemme try with windows tomorrow - from what I see in s-tui, the CPU max power draw is like 31-32W for the Package power, but CPU+GPU combined can draw 60W sustained (Psys).
Tried a bit on windows 10 & 11 today and they are all worse than Linux results
Windows 10 first run:
https://browser.geekbench.com/v6/cpu/18520337
Windows 10 second run:
https://browser.geekbench.com/v6/cpu/18520390
Windows 11 run:
https://browser.geekbench.com/v6/cpu/18520904
Due to modern standby it is not possible to use legacy performance power plan - I did slide the power slider to “best performance” in settings
PL1 on the processor is 35W and PL2 is 60W.
Despite the high PL2 I almost never see the CPU boost towards that. In Prime95 stress the highest it reached is around 45W and then quickly thermal throttles to 35W. At steady 35W the CPU is already running at 100C, so any warmer climate the sustained power is going to be lower than that.
With CPU+GPU load I see sustained combined power of 35W and temperature of 86C.
