I’m in Norway, so maybe they’re just collecting a bunch of stuff that will be sent to a hub somewhere in EU first
I’ve messed around with the new laptop a bit. I knew the display and power consumption were going to be much better than my old 11th gen, but it still rather blew me away both how vibrant and smooth the new display was and how much cooler and quieter the new processor runs. Can’t say much about the battery just yet (I plan on doing a full cycle to calibrate it before I set a charge limit), but given that my old battery degraded to like 84% health (about 46Wh), I expect it to be a massive improvement, even with an 80% charge limit.
I was thinking about making a support thread for this, but figure I could just ask here first: Does anybody have a suggestion of what percentage charge I should leave my old battery at for long-term storage (eg. a few years)? I plan on putting the mainboard from the old laptop in the standalone case, but was planning on keeping the old case and battery around as a potential spare, at least for a little while, but without a mainboard in it, I won’t have an easy way to check on or charge/drain the battery, so I’m trying to think ahead what would be a good charge level so I don’t have to think about it. I’m thinking somewhere between 60% and 80% would give it enough so that it doesn’t dip too low from slowly losing charge, but figured I should ask for opinions before going through with it.
Got mine this morning and I really like the feel.
Same boat, AMD, payment went through on the 19th, still waiting on the email…
I received the batch 10 x7 today. Took only 1 day to ship.
I currently run the framework laptop in a cooler master case, there’s 3d printable models that let you keep using the battery. the advantage of that is you don’t have to use a 100w charger to keep it on. if you want to store it however between 40-60 should be fine.
I swear there was a powerbank project for these batteries might be worth looking into
congrats to your company/family ![]()
I know for lithium polymer batteries you need to keep it loosely around 50% charge. It doesn’t need to be precise, 40-60% are all within the normal range.
Can’t speak for Li-ion but you could take a look at the battery and see if you can find a storage recommendation study on the specific chemistry. From a quick search many online sources recommend 50% for li-ion in general and often without citing any studies/discharge curves, so take them what you will. Personally I’d say keep it at a known percentage around 60%, but most importantly I’d check back in a year to get a grasp on how fast the battery loses charge when left in storage.
You could totally just leave it with 80% charge and it’ll be ok for a few years, but if you want to be reaaallly safe, check back in periodically. I’m saying this because recent technologies in batteries have some weird looking discharge curves (in lipo of course). Reason why I mention this is because there is no guarantee from which voltage will it start to drop off really quickly. Here’s an example of a random battery discharge curve, just know they all follow the trend.
I also saw this thread on stack exchange https://electronics.stackexchange.com/questions/491538/why-are-lithium-ion-batteries-stored-at-50-voltage-and-not-a-lower-voltage Where they talked about state of charge and relation to degradation. All batteries are different so grain of salt as per usual, good to get a grasp of the situation though.
I figured there’s other cases that would allow keeping the battery (seems like a good option, especially as a built-in UPS), but a) I don’t own a 3D printer (or know how I’d borrow one), and b) I already have a 100W charger and the cooler master case has already been ordered. At this point, I’m just going to plan around using it in standalone mode without the battery.
Has this type of delay been common before?
AMD Ryzen AI 300 Series mainboards
I did find a couple of Debian installation guides which cover the AMD mainboard, but not the Intel mainboard, but searching again, I can only find one of them, and later found an article on the official Debian wiki which I didn’t find in my initial search yesterday.
Intel Core Ultra Series 3 mainboards
Other than that, I don’t think many FW13 users who ordered the new Intel mainboard (or a FW13 or FW13 Pro with it) have them yet, but I’m sure there eventually will be more Linux guides for that.
As I previously mentioned, the Linux 7.2 kernel hasn’t yet made its way into Backports for Debian 13 yet, but is in the testing branch (which I incorrectly referred to as the unstable branch), and I just rechecked.
My plan was to clone the Debian installation from my previous laptop, but before I can clone it, I have to upgrade it and do some other prep work first since I pinned it on Debian 12 as I wasn’t using it as often as the Windows side. Judging by the file dates, I last used the Debian side around early to mid 2023, before the laptop’s keyboard started failing some time in 2024 and gave up entirely in March 2025.
However, I decided to load the Debian network installer in rescue mode so I could break out of the rescue mode menu and use the partitioner to prepare my SSD for the dual-boot configuration I plan to have (after which it tries to install a base system but I would go back into the rescue menu, unmount a bunch of binds, and delete the base system).
The Wi-Fi card doesn’t work in the installer, which in turn asks for the following firmware files:
iwlwifi-sc-a0-wh-b0-90.ucode
iwlwifi-sc-a0-wh-b0-91.ucode
iwlwifi-sc-a0-wh-b0-92.ucode
iwlwifi-sc-a0-wh-b0-93.ucode
I searched to see if I could find the Linux device firmware files for the Intel Wi-Fi 7 BE211, and found the driver download page on Intel’s website, but it mentions that it requires Linux (kernel) 7.2 or newer, which again, isn’t yet available in Debian 13 Backports, but should eventually be, and for those who came across this post some time in 2027 or later, Debian 14 should already have a new enough kernel version for it to work after installing firmware-iwlwifi.
Running lspci shows the Intel Wi-Fi 7 BE211 card as 00:14.3 Network controller: Intel Corporation Device e440 (rev 01), and uname -r on the Debian 13.7 network install image shows the kernel build as 6.12.107+deb13-amd64, which makes sense as Debian 13 uses Linux kernel 6.12, and the device name should show up correctly on kernel 7.2.
However, the Framework Ethernet expansion module does get recognised by the installer and I’m able to link up that way, which will help later in the cloning process when I’d want to chroot and probably run APT.
Nice, super exciting!
I completed memory testing on my third party RAM yesterday with no errors, so am good to go on the hardware front!
Next, I installed Ubuntu 24.04 LTS with the framework ISO and everything worked smoothly. I plan to test some local LLMs with the new machine so tried spinning something up quickly. Ollama wouldn’t recognize the GPU so was running on 100% CPU
. Ollama/Intel docs suggest that Ubuntu 26.04 is needed with Panther Lake so will try that tonight.
My hope is that I will ultimately be able to replicate this in Debian.
On the Debian setup front, I reached the same conclusion that setup would be challenging without an internet connection because of the wifi driver issue. I didn’t order an Ethernet expansion card, so I’m going to try with an Ethernet to usb adapter tonight. The tentative plan will be to install stable and then update the kernel to 7.1 with trixie backports.
Is there a particular reason why you chose Debian? I’ve been genuinely curious for the longest time, and never actually seen anyone run Debian in person. Ubuntu is as far as I’ve seen people go.
I wasn’t gonna poke at this question but it seems quite a few people in FW community (and r/) are interested in running Debian… Far as I know Debian is old and needs constant backports for modern features work, and I just never thought it’s worth the effort. Are you guys working with Debian servers or is there something I’m missing?
are batch same for AMD/Intel ? FYI I got my paid email, sunday morning
yea.. same here
Hey, just got my tracking number. and it’s actually already shipped since 24 hours but framework didn’t sent me the tracking number
Mine has also been on its way since yesterday despite only getting the tracking number just now. Delivery supposedly on Monday, hopefully just a pessimistic estimate though and it still occurs this week ![]()
I started with Ubuntu in 2008 but moved to Debian in 2015. Moving from Ubuntu to Debian meant that I could use a lot of the tricks I learnt from Ubuntu tutorials without some of Ubuntu’s handholding features getting in the way and treating me like a Linux beginner, and I could still download and DEB packages for Linux versions of apps that aren’t available in Debian’s APT repositories.
I have tried some other distros like Fedora and openSUSE Leap over the years but couldn’t get accustomed to using them. I plan to try Fedora, openSUSE, and a few other distros in VMs, but don’t currently have the time to do so.
On systems where I do run stable releases of Debian, like my primary PC and my NAS, I get around the old software release issues by installing Flatpak and using that to install and run newer versions of apps from Flathub, but in some cases, I might download a tarball version of an app and install it to a folder within the opt folder, or install the app I want from Debian Backports instead (e.g. sudo apt -t trixie-backports install <package name> on Debian 13).
got my shipped email, then checked shop for tracking, and it missed the plane out of Taiwan, hopefully it’ll be on the next one out. Estimate is it will be here in Wyoming on Monday. Annoying I have to wait another weekend but is what it is.
me too ![]()
